It is currently Mon Aug 04, 2025 10:03 pm
 Post subject: Parlor bracing
PostPosted: Mon Apr 13, 2009 6:56 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
There was some discussion a while back about the LMI plans for a parlor guitar being substantially over-braced. Well. I'm just about to start cutting braces, and I'm wondering how far I can push this thing (BTW, this is my first).
According to the plans, the top braces are 5/16" wide and 1/2" deep. I assume I can take the width back to 1/4" pretty easily. Any more than that, do you think?
And depth-should they be scalloped with the peaks at 1/2"? Or lower?
Thanks in advance for the help.
 Post subject: Re: Parlor bracing
PostPosted: Mon Apr 13, 2009 7:37 pm
1/4 wide 9/16 high is all you need on the X braces Tone bars 1/2 high. If you are under the 0 size you can put 1 tone bar and 1 finger brace.
john hall
PostPosted: Mon Apr 13, 2009 7:48 pm
Last Name: Denvir
City: Baltimore
State: ON
Thanks John, I also found a bunch of stuff in the archives. Amazing what can happen when you hit that search button, isn't it :-)
PostPosted: Mon Apr 13, 2009 9:30 pm
Last Name: Livermore
State: Minnesota
Steve,
Make sure you take note that the top and back braces are imposed on the same image, which means that the lower legs need to be opposite how they appear on the Antes plan.
In other words, when you brace up the top, you need to turn the plan over to get the correct layout.
Ditto on the brace advice. 1/4" is all the wider you need to go, as a rule of thumb of course, and 9/16" high at the X ( I think I went 1/2" and was fine.)
Good luck with the build.
PostPosted: Tue Apr 14, 2009 4:44 pm
Don't forget the scale length.
If the scale length is shorter, you can thin everything more.
If the scale length is a standard, 24.9, 25.4, then your braces and top thickness should be standard also.
Just because a guitar is smaller, the scale length still dictates the tension on the top.
PostPosted: Wed Apr 15, 2009 11:25 am
Todd, all those ciphers look about right. pfft
Users browsing this forum: TimAllen and 10 guests
