It is currently Tue Aug 05, 2025 5:49 am
 Post subject: slotted headstock angle?
PostPosted: Thu Apr 30, 2009 10:46 am
State: ON
I’m in the process of finishing up the design work for my first slotted headstock guitar. I’m just wondering if the peghead angle for the slot headstock is the same as for a solid headstock or is it a lot different? Right now I am using 14 degrees.
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Thu Apr 30, 2009 11:24 am
First name: Richard
Last Name: Gagnon
City: Port Alberni
State: BC
Hi Josh,
I have plans for a OOO slot head that calls for a 10 degree headstock angle. From what I understand, a 15 degree angle would be on the steep side since the break angle for the strings is to the middle thickness of the headstock rather than the post sitting on top.
I think, therefore I am....often confused!
PostPosted: Thu Apr 30, 2009 12:21 pm
Josh,
Unless you're trying to replicate a vintage instrument of some kind, 14 degrees works fine. There's nothing wrong with a steeper break angle at the peghead. I've built guitars with a 30 degree scarfed peghead without any problems.
Jimmy Caldwell
PostPosted: Thu Apr 30, 2009 1:01 pm
I'd draw it out on paper to see if 10 degrees will yield an average 15 degree string angle on a slotted head stock but I suspect this is a rule of thumb not written in stone, so-to-speak.
Intuition tells me better to be more of a break angle than under.
Wade
Nashua, NH
http://www.wadefx.com
PostPosted: Thu Apr 30, 2009 1:30 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
I use 10 degrees also.
For the very reason Richard stated.
Plus it looks right also.
Mike Collins
PostPosted: Thu Apr 30, 2009 1:34 pm
Last Name: Collins
City: Argyle
State: New York
The strings will ride on the wood ramps if the angle is steep.
Removing more wood there to compensate will weaken the area .
Mike Collins
PostPosted: Thu Apr 30, 2009 2:06 pm
Do I hear 11 ... going once ... thats right, goes to 11 ....
PostPosted: Sat May 02, 2009 10:45 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I always assumed the angle was the same. I made my 12 fret neck template from a slothead Martin I was doing a neck reset on. I'll have to check and see what the angle is.
PostPosted: Sat May 02, 2009 3:08 pm
i once came across an article by Mr.Somogyi about the guitar's neck and it's design.
he stated that 10 degress on a slothead os what he uses and so thats what i've been using ever since though funnily enough that didnt make my guitars sounds like his ;)
PostPosted: Sat May 02, 2009 9:38 pm
State: ON
Thanks guys, it is helpful to know what others are doing. I see the logic in using the 10 degree angle and I think that is what I will try first.
Josh
Josh House
Users browsing this forum: doncaparker and 33 guests
