It is currently Tue Aug 05, 2025 9:00 pm
PostPosted: Mon Jun 01, 2009 8:15 pm
Greetings from CT! My name is Rodger and I am primarily a lurking, amateur electric bass builder.
I bought my first fret saw recently and, like many others who have purchased this model, am frustrated with the performance. The teeth are just plain dull. I pull, it goes bumpa-bumpa and wanders. If I wanted a textured fret slot, this is the go-to tool. If Zona would make a saw in the .023" ballpark, I would buy one now and save myself the hassle, but I really am interested in sharpening the saw I have.
There are no handsaw sharpening services near me in CT (that I am aware of) and I don't mind sending the saw to a reputable sharpening service and paying for postage. Any references are appreciated and Northeast USA is preferable. Thank you for your input. Hey- if you offer this service, please let me know.
Rodger
PostPosted: Mon Jun 01, 2009 9:02 pm
-Mark Grable in Vermont does excellent work, specializing in japanese
saws, but he also sharpens western saws (or used to anyway).
His email is japanesehandsawsharpener@yahoo.com, but calling
him might be better, at 802 885 3376. CW
PostPosted: Mon Jun 01, 2009 9:10 pm
Last Name: Speller
City: Rodney
sorry i can't answer your question but just so we don't go out and buy that certain fretsaw? what make is it? im going to be looking for a miter box and fretsaw set soon myself.
PostPosted: Mon Jun 01, 2009 9:21 pm
Welcome Rodger.
http://www.japanwoodworker.com/product.asp?s=JapanWoodworker&pf_id=07.117.120&dept_id=13085
Its not a Zona, but it might work for you anyway.
PostPosted: Tue Jun 02, 2009 7:18 pm
Thanks for the replies and the recommendations.
It is a Stew-Mac .023 fret saw. The quality of the steel seems to be fine, the slot that it cuts at the moment is a rough .026-.027". When it is sharpened, I'm wondering if it will narrow that a bit. I don't have $ to throw around, so sharpening an otherwise decent tool makes more sense now. Thanks again!
Rodger
That Japanese Hishiki looks like a real beast!
PostPosted: Tue Jun 02, 2009 8:26 pm
Last Name: Marcq
City: Allenstown
Zip/Postal Code: 03275
If the kerf is a bit ragged and too wide, have you considered grinding off a bit of set? I do it to my dovetail saws (cheaper ones) and it is the simplest, quickest way to improve the cut. Put the saw flat on a board with the spine off the edge and take 2 passes on each side touching only the sides of the teeth (even pressure) with the edge of an oilstone. Do a test kerf, measure, and repeat as necessary until it cuts the kerf you want. Just remember even # of passes per side, same amount of pressure, or it will cut circles - like my right-handed chainsaw used to do...
Last Name: Marcq
City: Allenstown
PostPosted: Wed Jun 03, 2009 6:01 pm
Steve, thanks for the idea of narrowing the set this way. Since I use scary sharp papers on a granite plate, I have no oilstone, but I have a utility 300g diamond honing plate I could try.
Rodger
PostPosted: Wed Jun 03, 2009 6:42 pm
http://www.boggstool.com/
Originally recommended by someone else. Todd Stock, I think. But I always seem to be wrong about who said what on this forum.
PostPosted: Wed Jun 03, 2009 8:55 pm
I'm learning (more each time) how to sharpen my own dovetail saw which I got to the right set for a fret kerf. It is not that hard, just need a 4" double extra slim taper (which Ace will order in for you) and a Google search for How To.
I always vote for do it yourself.... so far :)
PostPosted: Fri Jun 05, 2009 4:31 pm
http://www.taunton.com/finewoodworking/ ... x?id=24976
This looks like something I can tackle.
PostPosted: Sat Jun 06, 2009 9:29 pm
First name: Mark
Last Name: Kosmowski
City: near Syracuse
I'm coming from a general woodworking background and haven't done any lutherie yet, so take the below with whatever seasonings are needed.
For sharpening handsaws, after filing the teeth, a saw set is used if needed to return teeth to the proper set to give a uniform kerf. These are some examples of set tools. I have not used a set tool nor indeed even resharpened a handsaw yet, but was educated about the existence of these devices at a recent woodworking show that had seminars in addition to a vendor hall.
I hope this is helpful to you. Best of luck with your sharpening!
PostPosted: Sun Jun 07, 2009 12:04 pm
Before you mess with it, you could just send it back to Stew Mac and they will replace it.
PostPosted: Sun Jun 07, 2009 1:00 pm
Location: Between Bordeaux and the Atlantic. S.W.France
As Howard says, Stewmac give excellent service (second to none) if anything they sell is found to be faulty or sub-standard.
PostPosted: Tue Jun 09, 2009 6:36 am
Mine did the same thing and I tried putting candle wax on the teeth as I made each cut, and it made a big differance. bliss
We Bend the Wood, So You Can Bend the Strings
Users browsing this forum: FlyingFred and 42 guests
