Fisheyes......... I HATE fisheyes http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=22836 |
Author: | mhammond [ Tue Jun 23, 2009 12:16 am ] |
Post subject: | Fisheyes......... I HATE fisheyes |
The guitar before last had fisheyes in the KTM-9 ![]() |
Author: | Dave Fifield [ Tue Jun 23, 2009 4:00 am ] |
Post subject: | Re: Fisheyes......... I HATE fisheyes |
I hear ya! Annoying aren't they?! What kind of wood is giving you all this grief? I thin out the Z-Poxy finishing resin a bit with de-natured alcohol - it seems to help a bit, but then you have to give it 3 coats of Z-Poxy to make sure all the pores are filled. Can't win! ![]() I'm not sure what you mean by having to sand back to the bare wood - you're supposed to do this between coats of Z-Poxy filler anyway I thought, so that you end up with a totally flat surface with all the pores filled (they should look like tiny shiny dots when you are done)...? I thought I'd heard it wasn't only silicone deposits that did this, but pretty much any mineral deposit in the pores. I'd like to learn more about this if anyone knows the whole truth here...... Cheers, Dave F. |
Author: | Barry Daniels [ Tue Jun 23, 2009 7:54 am ] |
The problem could be stearates in the sandpaper. I am not familiar with the Norton brand, so you might want to check that out. |
Author: | Piiman [ Tue Jun 23, 2009 9:08 am ] |
Hesh once warned me about the none slip router mats containing silicone |
Author: | jackwilliams [ Tue Jun 23, 2009 10:40 am ] |
Dave wrote:"I'm not sure what you mean by having to sand back to the bare wood - you're supposed to do this between coats of Z-Poxy filler anyway I thought, so that you end up with a totally flat surface with all the pores filled (they should look like tiny shiny dots when you are done)...?" Jack replies: As long as you are still seeing "shiny spots", the pores are not completely filled. |
Author: | npalen [ Wed Jun 24, 2009 2:02 pm ] |
Fish eyes are not all that bad if properly prepared. ![]() |
Author: | SteveSmith [ Wed Jun 24, 2009 2:09 pm ] |
npalen wrote: Fish eyes are not all that bad if properly prepared. ![]() Tobasco and some lemon helps. |
Author: | WaddyThomson [ Wed Jun 24, 2009 3:35 pm ] |
SteveSmith wrote: npalen wrote: Fish eyes are not all that bad if properly prepared. ![]() Tobasco and some lemon helps. Yeah, but you can suck on one for hours and it will never melt! ![]() |
Author: | mhammond [ Wed Jun 24, 2009 5:26 pm ] |
This thread has turned revoltin' |
Author: | StevenWheeler [ Wed Jun 24, 2009 7:01 pm ] |
At least it's not fish heads! I'd look to another source for the contamination. Norton sandpaper is all I use and I've not had any fisheye problems. |
Author: | mhammond [ Thu Jun 25, 2009 12:15 am ] |
I'm thinkin' now it might have been the cup I mixed it in. I hope! ![]() ![]() ![]() |
Author: | the Padma [ Thu Jun 25, 2009 11:03 pm ] |
contamination: Fish eyes are craters that have a bit of material remaining in the center. Water, oil and silicone are the three major culprits. Air supply (needs good filtration, no oil, no water, extremely clean), environment (are you around any silica sand producers, is there any caustic or acid around, etc...), blessings the Padma |
