It is currently Thu Aug 07, 2025 7:32 am
PostPosted: Tue Jul 07, 2009 4:10 pm
When following a standard layout pattern making a dreadnaught with a Venetian cutaway, the thumbeam (at least on my shape) ends up having quite a bit of it's length running along the curve of the cutaway. The same thing with the first back brace. So I just moved the TB forward towards the neck block until the sides intersected more or less square again. But now there is a 1/2" ish gap between the thumbeam and the soundhole edge. I'm wondering if there could be future negative consequences to this approach.
Does any one have any thoughts?
What do some of you folks do?
Thanks...
PostPosted: Tue Jul 07, 2009 4:18 pm
If required .. angle it some .. i do that on the first back brace quite a bit .... the top UTB I usually chop and let into the side ...
Users browsing this forum: zmp2 and 36 guests
cron
