It is currently Fri Aug 08, 2025 12:49 am
PostPosted: Sat Aug 22, 2009 10:38 am
I am trying to have ebony binding with a small strip of red purfling on the side. Is it possible to glue the side purfling to the ebony binding first and then bend both together in the side Fox bending jig with a heat blanket, or will it just all fall apart?
Bill
Formerly know as Mandodiddle.
PostPosted: Sat Aug 22, 2009 10:53 am
First name: jack
Bill,
That's the way I'd do it... glue the red side binding to the ebony first then bend it in the fox style bender. I use CA glue for this.
I usually try to 'gang' the bindings together with masking tape at the ends to avoid the possibility that the binding roll or twist when bending.
regards,
jack
PostPosted: Sat Aug 22, 2009 11:13 am
Bill,
It will work! I use Titebond 2 or 3 for this but I think any titebond will work also.
Burton
Brookline, MA.
PostPosted: Sat Aug 22, 2009 3:51 pm
Thanks Jack and Burton. I'll go for it.
Bill
PostPosted: Sun Aug 23, 2009 4:34 pm
Thanks Todd.
Bill
