It is currently Fri Aug 08, 2025 12:48 am
PostPosted: Thu Sep 03, 2009 7:11 am
First name: Sondre
Country: Norway
I'm restoring a 70s Taylor 855 with the moustache bridge. The bridge pins are missing, and I don't know which taper will fit the holes best (3-degree or 5-degree..?). The holes are full of glue sqeeze out, so I will have to re-drill the holes. Don't wanna mess things up by starting with the wrong reamer... Thanks!
Sondre
PostPosted: Fri Sep 04, 2009 4:13 am
First name: Jim
Last Name: Hansen
I can't answer your question, because I don't know, but I do know that Taylor is really good about answering questions like this.
If you strike out here, you might send them a note.
Jim Hansen
