It is currently Fri Aug 08, 2025 3:06 pm
 Post subject: Cutting Lexan
PostPosted: Tue Sep 22, 2009 4:18 pm
What is the best way to cut Lexan? I intend to use it as a template so I want the edges to be nice and smooth. I've cut acrylic and other plastics with a bandsaw only to have the kerf close up when the melted plastic puddled together. Same thing happened with a tablesaw, except I was also burned when it tossed a glob of melted plastic onto my hand.
 Post subject: Re: Cutting Lexan
PostPosted: Tue Sep 22, 2009 4:23 pm
Lillian, I just use my table saw, band saw and spindle sander to cut and shape Lexan (which is a name brand for polycarbonate material). Acrylic can melt easier than polycarbonate. You should be fine using your saws and sander on it.
PostPosted: Tue Sep 22, 2009 4:38 pm
Thanks Rod.
PostPosted: Tue Sep 22, 2009 4:58 pm
Oh yeah. Cuts much cleaner and no burns.
PostPosted: Tue Sep 22, 2009 8:13 pm
First name: Matthew
Last Name: Rust
City: Columbus
Zip/Postal Code: 47201
I cut it on the band saw to within 1/4" or so of my final line and then touch it up on an OLD belt on the belt sander. Then use a small sanding block to soften the edges a bit.
Don't confront me with my failures--I have not forgotten them.
PostPosted: Wed Sep 23, 2009 12:00 am
Those edges are sharp. Thanks for pointing that out.
Users browsing this forum: KyleU and 8 guests
