Roto-zip Lewis-Carol rossette cutter! http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=24088 |
Author: | Frei [ Wed Oct 07, 2009 2:47 pm ] |
Post subject: | Roto-zip Lewis-Carol rossette cutter! |
Looks like this will work. ![]() Problem is , I have a first generation rotozip, do they all have the same base?- I am using a 3 point mounting system, one is a screw in the back of the base??? ![]() |
Author: | TonyKarol [ Thu Oct 08, 2009 4:40 pm ] |
Post subject: | Re: Roto-zip Lewis-Carol rossette cutter! |
![]() ![]() looks like it will work just fine .... BTW .. the idea behind my making this in the first place belongs to the late Richard Schneider - I modded a similar design of his that used a blade to accept a lam trimmer, an used UHMW plastic instead of machined aluminum/steel. |
Author: | ChuckB [ Thu Oct 08, 2009 5:09 pm ] |
That's the weakness of the rotozip, poor base made of plastic with inaccurate depth control. That said, I have used a rotozip on my first couple of guitars for routing binding channels with good results. Even with a homebuilt modified base that I built, it was too time consuming setting the depth accurately... I now use a Bosch Colt for bindings. But if time was spent to build a base with accurate depth control, the rotozip has ample power and a decent collet. Chuck |
Author: | TonyKarol [ Thu Oct 08, 2009 5:19 pm ] |
Good point Chuck .. I was talking only about the base when I said it should work, but I have no idea how good/bad a rotozip is .. never realy looked at one. get a PC7310 .... works for me .. all 7 of em !!! |
Author: | LanceK [ Thu Oct 08, 2009 5:48 pm ] |
TonyKarol wrote: laughing6-hehe .. so some imposter named Carol is ripping me off now ... yeah it happens, but it really does start with a K ![]() looks like it will work just fine .... BTW .. the idea behind my making this in the first place belongs to the late Richard Schneider - I modded a similar design of his that used a blade to accept a lam trimmer, an used UHMW plastic instead of machined aluminum/steel. Oddly enough, there was a "Carol" selling guitars in Montreal this year too! ![]() |
Author: | Frei [ Thu Oct 08, 2009 6:01 pm ] |
Sorry bout dat....! ![]() |
Author: | Frei [ Thu Oct 08, 2009 6:45 pm ] |
I think I was thinking of "Louise' and Clark", so the "pioneer" thought was behind the post... #*#*(@&&! ahm... ![]() |
Author: | TonyKarol [ Fri Oct 09, 2009 8:34 am ] |
Yes there was Lance ... but also oddly enough, I ended up with HIS money !!! |
