It is currently Sat Aug 09, 2025 12:38 pm
PostPosted: Sun Nov 08, 2009 10:36 am
Last Name: Neal
City: Arcadia
State: ok
Zip/Postal Code: 73007
Anyone have an alternative (cheaper than a reaming tool) to tapering bridge pin holes?
PostPosted: Sun Nov 08, 2009 10:44 am
I use a cheap electronics/plumbers tapered reamer ( I have had it for years, bought it a radio shack a long time ago) .. it worked out to 3.5 degrees - close enough, considering it cost about 6 bucks.
PostPosted: Sun Nov 08, 2009 11:51 am
I've used the tip section of a 3/16" round double cut tapered file in the past. Chucked in my hand drill and spun backwards worked well. The taper is very close to the same as a 3* pin.
PostPosted: Sun Nov 08, 2009 3:24 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
I as well use the tip of an file - I have an standard 8" mill file and the taper on the tip works perfectly for reaming pin holes.
I just filed the edges clean and ream by hand....
PostPosted: Sun Nov 08, 2009 3:49 pm
First name: Tom
Last Name: West
State: Nova Scotia
A machinist friend may have a tapered pin reamer. If memory serves me right,it would be a #3.
PostPosted: Sun Nov 08, 2009 5:22 pm
First name: David
Last Name: Malicky
Zip/Postal Code: 92111
It's not an alternative, but I've used this ($3.49 and decent quality):
http://www.harborfreight.com/cpi/ctaf/d ... mber=66936
The included angle is 6 degrees (1/8 to 1/2 dia over 3.6")... seems fine for 5 deg pins. For 3 deg pins, I drill 3/16" through, then send the reamer down part way until the pin is fully seated.
But I like the file tang idea above... mine also measure 6 degrees.
David Malicky
PostPosted: Sun Nov 08, 2009 6:31 pm
If you use 3 degree pins, this tool works OK
http://grizzly.com/products/3-Bridge-Pin-Reamer/H5808
Mike Franks
http://www.mjfranksguitar.com
PostPosted: Sun Nov 08, 2009 8:25 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
For Canadian guys do you realize Grizzly won't ship to us in Canada, they have a deal with Busy Bee that prevents it. the pain is that Busy Bee does not sell any Luthier stuff, go figure.
Fred
Fred Tellier
PostPosted: Mon Nov 09, 2009 10:12 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
Thanks for that bit of info, Fred. Good to know before i make an order, could also be why that won't ship me a catalog...
This thread came up very timely, as I was about to call in a favour for a bridge pin reaming with a friend this morning. I didn't feel that was worthwhile paying a lot for a reamer to use just for one guitar. I build classicals, and I have a Panormo copy that i am just about finished and it uses a pin bridge.
Anyway, inspired by the file tang idea, I went out into the shop last night and checked out one of these little needle files that I picked up on the cheap some years back. Wouldn't you know it, the taper was a perfect match for the 3 degree pins that I have! I just tapped off the little plastic cap on the handle, slipped it into the drill press, and it made a nice taper in a pre drilled hole.
I checked out another reamer that I inherited. While not a pin reamer, it was close (maybe 5 degrees?), but not as close as the little file which was perfect.
http://redrivercanoe.ca/
Users browsing this forum: No registered users and 44 guests
