Workbench finish
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=24596
Author:  Edward Taylor [ Sat Nov 14, 2009 10:36 pm ]
Post subject:  Workbench finish
What is the best finish to use on a workbench? I am using good one side plywood, and mainly just want to seal it so nasty stuff does not seep into the wood. Will any varnish do?
Thanks a bunch
Author:  runamuck [ Sat Nov 14, 2009 11:18 pm ]
Post subject:  Re: Workbench finish
Whatever you put on it wax it. If you get glue on it - and you will - it will chip off easily.
Author:  SteveSmith [ Sun Nov 15, 2009 7:06 am ]
Polyurethane with wax over it.
Author:  SteveCourtright [ Sun Nov 15, 2009 9:38 am ]
No finish is also a viable option.
Author:  Edward Taylor [ Sun Nov 15, 2009 9:56 am ]
Thanks for the replies. I like the idea of tung oil. I looked on the waterlox website and I see their original sealer is a tung oil product. Would this be any better than regular tung oil? I found a place in the city that sells it and my dad just so happens to be going down to the city tomorrow and will be near that store. But I have regular tung oil on hand if its all the same.
Author:  JohnAbercrombie [ Sun Nov 15, 2009 2:35 pm ]
I like oil on my benches- easy to renew/touch up. Periodically I clean up the bench top with scraper or ROS sander and slap on more oil. Any Danish oil/tung oil seems to do. It's also a good place to get rid of the last of the oil when working on projects.
I keep wax far away from my wood projects, except for a very well-buffed, thin coat on the tablesaw.
Author:  Edward Taylor [ Sun Nov 15, 2009 9:17 pm ]
Alright I will just use regular tung oil, sounds good. For my go-bar section I am using melamine for the countertop, wood glue wont stick to that will it?
Author:  JohnAbercrombie [ Sun Nov 15, 2009 10:15 pm ]
Once the melamine surface gets a bit scuffed up, glue will stick to it. Hide glue and polyurethane are both pretty 'grippy'.
Just to be inconsistent (see my previous post about waxing the bench-top) I use wax paper where I want to keep things from getting accidentally glued together.
As an aside- don't make the 'upper plate' of your go-bar deck slippery. Those sticks can be nasty if they slip out of place.
Author:  Brock Poling [ Mon Nov 16, 2009 7:56 pm ]
Todd Stock wrote:
I was gonna say stick a piece of indoor/outdoor carpet to the underside of the upper deck...I require safety glasses anytime anyone is around one.
That is a cool idea.
Author:  woody b [ Mon Nov 16, 2009 8:32 pm ]
Mine isn't finished, but the next time I replace the (plywood) top I'm probably going to finish it with polyester.
Author:  woody b [ Wed Nov 18, 2009 6:50 am ]
Honestly, I'd use an easily repairable finish. I'm not sure poly fits that category. The nice part with any wipe on finish is ROS followed by finish wipe is literally a 90 second job.
Filippo
Like I said, mine is unfinised now, but I may finish my next with polyester. Polyester is tough as nails. An invisable repair wouldn't be necessary on a bench top. If I dropped a chisel and put a gouge in it I could just fill the gouge with CA. If I spilled something on it I could just clean it up with acetone or lacquer thinner.
Author:  David C. Hurd [ Wed Nov 18, 2009 9:12 am ]
I have a large roll of heavy brown wrapping paper that's 3 feet wide. I tear off a length ~ a foot longer than my work bench and fold all four excess dimensions under the 3/4" plywood sheet that's my work bench. Beautiful, clean surface that also doubles as a notepad and sketch board. When the paper gets glue bits and so forth on it, time to tear off a new sheet...
aloha,
Author:  Edward Taylor [ Wed Nov 18, 2009 10:19 am ]
Fillipo, I love your island bench, I wish to build one very similar if not the same. Can I ask, is that some sort of metal frame that holds up the top? Do you have any pics of that?
