bleeding
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=24659
Author:  James W B [ Wed Nov 18, 2009 6:55 pm ]
Post subject:  bleeding
When I shellaced a top the bloodwood around the Rosette bled into the Spruce.I`ve re-sanded and things look okay,but I`d like to get a coat of shellac on before the finish goes on.I`m gonna try that Emtech 6000.Do I dare risk it bleeding again or is ther another solution?
James
Author:  TonyKarol [ Wed Nov 18, 2009 6:57 pm ]
Post subject:  Re: bleeding
are you wiping or spraying the shellac ??? spray a light fast coat, it wont have time to run.
Author:  mateo4x4 [ Wed Nov 18, 2009 7:01 pm ]
I would try on scrap first but CA might work. don't quote me on that! laughing6-hehe
Author:  James W B [ Wed Nov 18, 2009 7:02 pm ]
Thanks Tony,I just brushed it on ,in my stupidity.I`ll spray a light coat on.
James.
Author:  Alan [ Wed Nov 18, 2009 8:52 pm ]
I would be very careful using CA around the soundboard. If you get it on the spruce top, you will have a yellow stain that you can't get off.
Author:  Erik Hauri [ Wed Nov 18, 2009 8:58 pm ]
CA will bleed bloodwood. Word.
Author:  Dennis Leahy [ Wed Nov 18, 2009 9:15 pm ]
I don't have a solution, but every time that I hear that Bloodwood bleeds I think about the irony.
Dennis
Author:  SteveSmith [ Wed Nov 18, 2009 9:40 pm ]
I went through this not too long ago and there's a lot of information in this thread:
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=22956&st=0&sk=t&sd=a
I was trying to avoid spraying but it just turned out that the best solution was to spray several light coats of shellac.
Author:  wbergman [ Thu Nov 19, 2009 12:26 pm ]
Jose Oribe is a top classical builder. Years ago, when he was a one man shop, he wrote that his wife helped before he finished by using a small artist brush to paint all the purflings with a laquer that would prevent bleeding. So, test your wood species with a laquer and maybe you will want to do that.
Author:  James W B [ Thu Nov 19, 2009 6:27 pm ]
Thanks for all the replies.What works is what Tony said.I sprayed a few light coats of Zinser seal coat shellac.The stuff that`s wax free,it worked great.
James
Author:  the Padma [ Thu Nov 19, 2009 7:05 pm ]
James W B wrote:
When I shellaced a top the bloodwood around the Rosette bled into the Spruce....
James
Now you know why itsd called blood wood.
Seal it first.
the
Padma
Author:  Ken Franklin [ Fri Nov 20, 2009 9:52 am ]
If you don't want to get out the spaying equipment for such a small job, you can french polish successive thin dry coats of shellac. Use a small piece of rolled up t-shirt and keep a fresh surface. Let it dry between coats. Two or three are fine. I watched Kenny Hill's french polisher and he was done in a jiffy, moved right into the whole french polish job from there.
