It is currently Sat Aug 09, 2025 7:00 pm
 Post subject: bleeding
PostPosted: Wed Nov 18, 2009 6:55 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
When I shellaced a top the bloodwood around the Rosette bled into the Spruce.I`ve re-sanded and things look okay,but I`d like to get a coat of shellac on before the finish goes on.I`m gonna try that Emtech 6000.Do I dare risk it bleeding again or is ther another solution?
James
James W Bolan
Nashville Tennessee
 Post subject: Re: bleeding
PostPosted: Wed Nov 18, 2009 6:57 pm
are you wiping or spraying the shellac ??? spray a light fast coat, it wont have time to run.
PostPosted: Wed Nov 18, 2009 7:01 pm
First name: Matthew
Last Name: Dollinger
City: Beaverton
State: Oregon
Zip/Postal Code: 97005
I would try on scrap first but CA might work. don't quote me on that! laughing6-hehe
PostPosted: Wed Nov 18, 2009 7:02 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Thanks Tony,I just brushed it on ,in my stupidity.I`ll spray a light coat on.
James.
James W Bolan
Nashville Tennessee
PostPosted: Wed Nov 18, 2009 8:52 pm
I would be very careful using CA around the soundboard. If you get it on the spruce top, you will have a yellow stain that you can't get off.
PostPosted: Wed Nov 18, 2009 8:58 pm
First name: Erik
Last Name: Hauri
State: Maryland
CA will bleed bloodwood. Word.
The member formerly known as erikbojerik....
PostPosted: Wed Nov 18, 2009 9:15 pm
City: Duluth
State: MN
I don't have a solution, but every time that I hear that Bloodwood bleeds I think about the irony.
Dennis
Dennis Leahy
Duluth, MN, USA
7th Sense Multimedia
PostPosted: Wed Nov 18, 2009 9:40 pm
I went through this not too long ago and there's a lot of information in this thread:
http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=22956&st=0&sk=t&sd=a
I was trying to avoid spraying but it just turned out that the best solution was to spray several light coats of shellac.
PostPosted: Thu Nov 19, 2009 12:26 pm
Jose Oribe is a top classical builder. Years ago, when he was a one man shop, he wrote that his wife helped before he finished by using a small artist brush to paint all the purflings with a laquer that would prevent bleeding. So, test your wood species with a laquer and maybe you will want to do that.
PostPosted: Thu Nov 19, 2009 6:27 pm
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Thanks for all the replies.What works is what Tony said.I sprayed a few light coats of Zinser seal coat shellac.The stuff that`s wax free,it worked great.
James
James W Bolan
Nashville Tennessee
PostPosted: Thu Nov 19, 2009 7:05 pm
First name: duh
Last Name: Padma
James W B wrote:
When I shellaced a top the bloodwood around the Rosette bled into the Spruce....
James
Now you know why itsd called blood wood.
Seal it first.
the
Padma
PostPosted: Fri Nov 20, 2009 9:52 am
If you don't want to get out the spaying equipment for such a small job, you can french polish successive thin dry coats of shellac. Use a small piece of rolled up t-shirt and keep a fresh surface. Let it dry between coats. Two or three are fine. I watched Kenny Hill's french polisher and he was done in a jiffy, moved right into the whole french polish job from there.
Ken Franklin
clumsy yet persistent
Users browsing this forum: Chris Ensor, doncaparker and 46 guests
