Flat Sawn Scarf Joint?
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=24973
Author:  Charles Lushear [ Wed Dec 09, 2009 3:08 pm ]
Post subject:  Flat Sawn Scarf Joint?
Hello,
I want to do a scarf joint on a concert uke neck but the piece of maple is flat sawn. Will this be strong enough? I usually do my necks with close to quarter spanish cedar so i'm a little hesitant. Plus I'm quite the novice so I just thought I'd run it by you guys first.
By the way, any idea how you pronounce "padauk"?
Thanks for any advice,
Charles
Author:  Michael Dale Payne [ Wed Dec 09, 2009 3:21 pm ]
Post subject:  Re: Flat Sawn Scarf Joint?
For a uke probably so but see what others think as well
Author:  Ron Belanger [ Wed Dec 09, 2009 3:33 pm ]
The scarf joint will be plenty strong enough. Have you considered ripping it and gluing it to make a 1/4 sawn board.
Padauk is pronounced padook. [:Y:]
Author:  Daniel Minard [ Wed Dec 09, 2009 3:52 pm ]
I think it's pronounced PadOOK.
Author:  Barry Daniels [ Wed Dec 09, 2009 3:54 pm ]
Every fender neck is made from flat sawn maple. So this will work fine for a uke.
Author:  Ti-Roux [ Wed Dec 09, 2009 3:56 pm ]
It's more stability that quartersawn gives you...
Author:  Mike Collins [ Wed Dec 09, 2009 4:15 pm ]
All scarf joints are endgrain to side grain.
So a flat sawn head will still be glued to a side grain neck.
Is this clear for you ?
I'm terrible with words .
Mc ;)
Author:  Ti-Roux [ Wed Dec 09, 2009 4:35 pm ]
I know a guy who's a conceptor for a huge guitar company that you probably know, but i'll forget to tell both names..anyway. Companies who are using maple on flatsawn for electric necks are ONLY, and ONLY this from a $$$$$ perspective. It waaaay cheaper to cut wood on flatsawn, and cause maple is strong enough for a neck, on flat sawn, they use it. But the better way to build neck (said by his mouth..) is on quarter sawn. It won't be less or more strong, but wayyy wayy more stable. And that's the point. A more stable neck won't move, won't contract/discontract, etc etc. If you have a quartersawn neck, you'll see that you won't adjust the tross rod as many often as on a flatsawn one...
Author:  Jim Kirby [ Wed Dec 09, 2009 5:55 pm ]
p.s. Welcome to the group, Charles!
