Router bits
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=25077
Author:  Edward Taylor [ Thu Dec 17, 2009 11:39 am ]
Post subject:  Router bits
Would the 1/4" downcut end mill from LMI be a good choice for binding? I am going to be using a setup with an adjustable bearing so I need something 1/4". Also, what would you say is the most versatile size of inlay bit?
Author:  Barry Daniels [ Thu Dec 17, 2009 12:52 pm ]
Post subject:  Re: Router bits
I use a 1/4" downcut spiral carbide router bit. Works great and leave a very clean surface.
Author:  Edward Taylor [ Thu Dec 17, 2009 1:01 pm ]
Here is the one I am referring to:
http://www.lmii.com/CartTwo/thirdproduc ... =End+Mills
Its in the picture under code SPPRC
Author:  Rod True [ Thu Dec 17, 2009 1:26 pm ]
I've used a 1/4" downcut bit for binding channels and it worked great. Check out Routerbits.com which is about $11 less than LMI.
For inlay work, I use 1/32", 1/16" and 1/8" bits. I've just used upcut bits on the 1/32" as I feel there is little advantage of having downcut for such a small bit. The others I use downcut to make the edge cleaner.
Author:  Heath Blair [ Thu Dec 17, 2009 1:55 pm ]
i would also recommend http://www.mlcswoodworking.com. free shipping on all of their bits all of the time. ive ordered several and they seem to be good bits. 1/4" spiral downcut for binding works well. i cant comment on inlay as i havent done any.
Author:  Mike OMelia [ Thu Dec 17, 2009 2:02 pm ]
For the inlay bits, I found very nice ones on ebay: http://cgi.ebay.com/10-Piece-Carbide-Bu ... 230373306b
All kinds of sizes, 10 in a pack. (this is the seller I bought them from)
Author:  Edward Taylor [ Thu Dec 17, 2009 6:30 pm ]
Those all look like good sources guys and I will tab them for later use, but I need to get stuff from LMI so its easiest just to get it all shipped from the same place. My main question was just if that 1/4" "end mill" bit is the same as the regular 1/4" downcuts people use for binding. Is end mill essentially another word for router bit?
Author:  Bob Garrish [ Fri Dec 18, 2009 3:36 am ]
Yes
