Thickness for one piece LP or PRS style neck? http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=25079 |
Author: | Jojobilou [ Thu Dec 17, 2009 1:48 pm ] |
Post subject: | Re: Thickness for one piece LP or PRS style neck? |
For my second guitar, with a LP style neck and a 13° headstock angle, the thickness of the virtual blank (I used a scarf joint) is 2,3". Hope, it will help... ![]() |
Author: | Jojobilou [ Thu Dec 17, 2009 3:58 pm ] |
2.3" thick... ![]() For the laminated neck without scarf, I've done it for my first guitar, an explorer type, 26" scale, 5 laminations (3 maple, 2 wenge) and it is still there... ![]() A little tip for gluing a scarf joint on a laminated neck, without the "slipping" issues : http://www.lutherie-amateur.com/Forum/v ... 34#p290734 Ben |
Author: | JRE Productions [ Thu Dec 17, 2009 4:43 pm ] |
Hmm... When I do a laminated neck (but no scarf), I do a three piece. I use 1x3's which are 3.5" x 0.75". This causes the neck to be 2.25" wide and has enough room for a fairly large headstock. The 2.25" wide leaves a bit of room at the body/neck joint to trim. I think the 15/16th fret where most join is around 2-1/8" wide or so. Headstock size is going to be your determining factor on how tall the neck needs to be. Most gibson size headstock will fit in that 3.5" width. J |
