It is currently Mon Aug 11, 2025 8:41 pm
 Post subject: Placement of Nut
PostPosted: Fri Feb 05, 2010 1:36 pm
I'm curious about the different placements of a nut.
Some are on the flat part of the neck with the fretboard and some are on the headstock.
Are there advantages/disadvantages to one over the other?
 Post subject: Re: Placement of Nut
PostPosted: Fri Feb 05, 2010 1:37 pm
I don't think it matters as long as your geometry is correct. Maybe a little harder to fit on the angled headstock but that is my preference - I like the looks better.
PostPosted: Fri Feb 05, 2010 3:04 pm
The advantage of flat bottom nut location (eg; on the freatboard surface of the neck) is simply that you dont have to cut a slot and only need to taper the peghead veneer as a retaining surface. The disadvantage is that while unstrung they are easier to knocked loose
You need to make up your mind on this in the design stage on which way to go. If you go with the flat bottom on the neck you need to make your neck account for the nut lenght or else you move the neck joint fret inboard by the nut thickness. And this will affect the nut slot and bridge location accordingly
PostPosted: Fri Feb 05, 2010 5:09 pm
Thanks for the replies.
Mike [:Y:]
Users browsing this forum: DennisK and 27 guests
