Stickering my first sets http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=25989 |
Author: | mnemotorsports [ Wed Feb 10, 2010 2:12 pm ] |
Post subject: | Stickering my first sets |
Hey guys got a couple of basic questions I got my first set of wood in curly maple / wrc from cvt ![]() Do you recommend stickering or letting it sit to correct it? Do you put stickers (if that is what they are called) under the bottom piece of wood? Also would you do a rough thickness sanding before seasoning the wood. Any tips, advice, comments would be great. Thanks matt |
Author: | John A [ Wed Feb 10, 2010 3:00 pm ] |
Post subject: | Re: Stickering my first sets |
Do you recommend stickering or letting it sit to correct it? Sticker Do you put stickers (if that is what they are called) under the bottom piece of wood? Yes - so the air can get around the bottom piece as well Also would you do a rough thickness sanding before seasoning the wood. No - sticker as is - thickness sand then sticker again if you see cupping. |
Author: | Michael Dale Payne [ Wed Feb 10, 2010 3:12 pm ] |
Do you recommend stickering or letting it sit to correct it? Sticker with the high end of the cup up. That whay the weight of the stack will correct the cup over time. Do you put stickers (if that is what they are called) under the bottom piece of wood? Yes I noticed that you have the sets sickerd as pairs with one piece directly on its mate. You should have one plank per sticker level to allow eve air flow across both sides of each piece of wood Also would you do a rough thickness sanding before seasoning the wood. Sticker now and allow at the bare minimum 30 days. then rough thickness and re-sticker |
Author: | mnemotorsports [ Wed Feb 10, 2010 3:44 pm ] |
Thanks for the replies. The one double pair is because I ran out of stickers. I plan to go get more when the snow clears. I am going to move the pieces/stickers around so they all line up. Michael you said sticker with high end of cup up. Do you mean Like this ( ^ ) or like this ( U ). I think you mean ^. |
