It is currently Tue Aug 12, 2025 2:55 am
PostPosted: Wed Feb 17, 2010 2:48 pm
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
Is there any difference in the woods used for kerfing
Does the specie affect sound/tone?
Does it effect strength?
What do you use? Why?
Bob
PostPosted: Wed Feb 17, 2010 2:51 pm
First name: Evan
Last Name: McCartney-Melstad
I use cedar because I like the way it smells.
Evan McCartney
PostPosted: Wed Feb 17, 2010 4:05 pm
First name: Chuck
Last Name: Hutchison
City: Houston
I like mahogany reversed kerfed lining because I like the way it looks when you look inside the guitar. You don't have little pieces falling off where the braces attach like you do with regular kerfed lining. But, then again, some builders use solid linings.
Couldn't tell you about the difference of sound of using cedar, spruce, basswood, mahogany or any other species. Guess it depends on if you use hide glue or Titebond to attach it to the rims and plates.....ooooops
PostPosted: Wed Feb 17, 2010 5:14 pm
Mahogany, Spanish cedar, spruce, basswood, cherry, WRC, even walnut. Any stable and light wood. I wouldn't use cocobolo, ebony, or even maple. It would work, but add unnecessary weight.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Wed Feb 17, 2010 6:10 pm
I have been useing Ash and find it very good for lining.I plan on useing walnut, willow and poplar as well.
