It is currently Mon Aug 18, 2025 10:53 pm
PostPosted: Thu Sep 16, 2010 11:32 am
http://www.youtube.com/watch?v=stYNJlDW2yA
hope you enjoy this video
PostPosted: Thu Sep 16, 2010 11:56 am
First name: Bobby
Last Name: Masten
City: The Woodlands
Zip/Postal Code: 77380
Thank you John! While I've read of doing this procedure several places, the video makes it seem so much easier. I'm pretty sure that if not on my first attempt that somewhere along the line I would have drilled into my truss rod without your tip to reinforce the process. Thanks again and keep em coming!
Bobby Masten
PostPosted: Thu Sep 16, 2010 1:30 pm
First name: Tom
Last Name: West
State: Nova Scotia
John: Neat video ...! I do it some what similar but cut the heads off the brads and use them to drill their own holes. Never thought to glue the brads into the holes. Must try that next time.
Tom
PostPosted: Thu Sep 16, 2010 2:55 pm
I do the same thing but pull the 'pins' (I use the actual drill bits) as soon as the glue takes a set. I don't see any good reason to leave them in.
PostPosted: Thu Sep 16, 2010 2:58 pm
Same here!!!
PostPosted: Thu Sep 16, 2010 8:37 pm
First name: George
City: Seattle
Nice video, John, as usual. I did note that your hand blocked the view of you applying the glue to the brads. I've always been confused by the idea of leaving registration pins in place permanently. Would that make removing the fingerboard difficult should a repair be required sometime in the future? Not criticizing the technique, mind you. I'm just curious.
George :-)
PostPosted: Thu Sep 16, 2010 8:50 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
[quote="SCGib68"] I'm pretty sure that if not on my first attempt that somewhere along the line I would have drilled into my truss rod without your tip quote]
Been there, done that, got the t-shirt..... [headinwall]
PostPosted: Fri Sep 17, 2010 12:43 am
I use drill bit's and pull after the clamps are one and everything as well. However if you wanted to leave a little stub of a pin left you could use the .0625 plastic side dot material left just proud of the neck surface.
Users browsing this forum: Dmaxwell, Terence Kennedy and 39 guests
