fret popped http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=27154 |
Author: | Bailey [ Mon Apr 26, 2010 12:23 pm ] |
Post subject: | fret popped |
All strung up on my first fan fret classical....In tune....action PERFECT....and HARK....after 20 minutes of playing I hear a 7th. fret buzz and the fret has popped (arched) up in the center. I can easily push it back down but doesn't stay. I did CA the ends when I installed them. Can I use thin CA along fret and push into place until set....or is this a bad idea? Or....do I pop it off and install a new fret? My assumption is that SOMEHOW my fret slot ended up a hair wide. If a new fret has the same issue...what is my solution to this problem? Kent |
Author: | Barry Daniels [ Mon Apr 26, 2010 12:33 pm ] |
Post subject: | Re: fret popped |
Use a drop of thin CA and have a tool handy to push the fret down and hold it for several minutes. Don't let excess glue run down onto the finished neck as it will ruin the finish. |
Author: | JohnAbercrombie [ Mon Apr 26, 2010 12:36 pm ] |
Kent- Congrats on your new guitar! No harm in trying the CA 'quick fix' on this. If that doesn't work, then: I'd probably put in a new chunk of fretwire, for a start. If you are careful, you can 'ding' the tang a bit to make it fit tighter. If you check out the commercial tool for this, you can figure out how to improvise something in your shop. http://www.stewmac.com/shop/Fretting_supplies/Pullers,_nippers,_sizing/Fret_Fitter.html I think CA is better for 'insurance' with frets that fit reasonably well- I'd hesitate to depend on it to hold down a really loose fret, especially on a new guitar. Cheers John |
Author: | Bailey [ Mon Apr 26, 2010 12:42 pm ] |
Thanks, I have the CA ready to go and a 1 " wide 1/2 fret tall slotted stick to hold it in place for a few minutes. I hope it doesn't stain my fretboard. I'll try to wipe off any excess as fast as I can while holding it down. Kent |
Author: | Colin North [ Mon Apr 26, 2010 12:45 pm ] |
I have CA'd loose frets down too. Handy tip from someone on the forum (the name escapes me, but thank you) to spot small drops of CA was to use a needle with the end ground off the eye (I push the point into a dowel for a handle). A bit like a fountain pen nib, works really well. -Too late!!? |
Author: | SteveSmith [ Mon Apr 26, 2010 1:21 pm ] |
Not a pro but I've CA'd whole fretboards. Works fine; I learned it from a pro. |
Author: | Bailey [ Mon Apr 26, 2010 2:45 pm ] |
I actually took Johns advice and installed a new fret first. It held so far.....but didn't take much to pound it in. I may end up CA gluing this one in down the road anyway. The needle thing is a good idea. I've used a toothpick for tiny applications before. Kent |
Author: | Fred Tellier [ Mon Apr 26, 2010 3:35 pm ] |
Wax the fretboard on each side of the fret and run some thin CA under the fret, it will wick into the slot from there. I was the needle eye CA applicator contributor quite a while back, but the idea came from the model airplane fliers. If you put a drop of CA on a piece of wax paper it will lay there without hardening for quite a long time. If I need bigger drops than the needle eye gives I dip a pipette into the puddle of CA without sucking it in and you get a nice drop. That is how I do frets as it is easier to control than a full pipette. A word of caution though, don't lay your arm or elbow in the CA puddle on the wax paper, don't ask how I figured that out. A cheaper debonder is also available, nitro methane does a great job, they probably spill a life time supply for one of us while fueling a nitro dragster at the track. Fred |
