Wet sanding em6000 with mineral spirits http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=27454 |
Author: | patmguitars [ Wed May 19, 2010 7:05 am ] |
Post subject: | Wet sanding em6000 with mineral spirits |
Hey guys It seems that a lot of people are using this method. I used to wet sand em6000 with soapy water, but stopped because it would go through the finish too easily. I have been doing it dry for awhile. I have a couple of questions regarding wet sanding with mineral spirits: -How much do you use? Just a few drops or "full wet"? -Do you use it at all grades or at a specific point? -Do you use gloves and a respirator? Any other detail regarding this method would be appreciated. Cheers Pat |
Author: | Barry Daniels [ Wed May 19, 2010 7:38 am ] |
Post subject: | Re: Wet sanding em6000 with mineral spirits |
I have done one finish with EM6000. I used low-odor mineral spirits and it was pretty easy. You don't need a lot of the stuff. The mineral spirits seems to go further and last longer than soapy water. Definitely use rubber gloves but a respirator does not seem necessary if you have the low-odor stuff. |
Author: | SteveSmith [ Wed May 19, 2010 7:55 am ] |
I use about a 1/4" of the low-odor mineral spirits in the bottom of a tin pie plate. I just dip the sandpaper in it as I go to keep it clean. You can sand through the finish easy whenever you wet sand because the paper cuts so well. I've been wetsanding from 600 up to 2000 before I buff but not sure that's the best method. It worked good for me but I still want to experiment some. |
Author: | Andy Birko [ Wed May 19, 2010 8:14 am ] |
Have you tried dry sanding with stearated papers like 3M gold? I've only done a little bit of wet on EM (USL to be technically correct) but I much prefer the dry. If you haven't tried it - try it. |
Author: | Dave Stewart [ Wed May 19, 2010 9:08 am ] |
I used min. spirits on my last & it went well. I'm a believer in "soaking" the papers (in whatever medium) before using.... soak under spirits for a couple of hours. Then just lift out, use & return frequently... same procedure for all grades. Definitely use gloves (...sanded off more than enough fingertips by not using!) |
Author: | Rod True [ Wed May 19, 2010 9:24 am ] |
I'm a dip and sand person myself, not a soaker ![]() I start wet sanding with 1000 grit, everything before is dry, I start with 600 then 800 3M gold, if they had higher grits, I'd use them too before starting to wet sand. |
Author: | patmguitars [ Wed May 19, 2010 1:23 pm ] |
Thanks for the input guys The reason I was asking is mostly curiosity. I seem to read more and more about people going wet and mineral spirits. I am just about to start the sanding stage on a customer guitar. I think I'll stay with my usual M.O. for now: dry sand with 800 to 2000, buff, Nu Finish Scratch Doctor and Bob's my Uncle! Pat |
Author: | Alain Moisan [ Wed May 19, 2010 1:44 pm ] |
patmguitars wrote: ... Nu Finish Scratch Doctor and Bob's my Uncle! I've been thinking about trying that out myself. I'll give it a try on the next one. |
Author: | patmguitars [ Wed May 19, 2010 2:22 pm ] |
Alain wrote: Quote: I've been thinking about trying that out myself. I'll give it a try on the next one I have tried a few other brands, including the new stuff from Magiuars (Scratch X2). I find that Scratch Doctor is the better one for what I do. Just remember to do only small surfaces at a time, use small dabs and don't let this stuff sit on the finish too long, it may start to "penetrate" the finish and soften it. ![]() Good luck with it! Pat |
Author: | Alain Moisan [ Wed May 19, 2010 2:38 pm ] |
patmguitars wrote: Alain wrote: Quote: I've been thinking about trying that out myself. I'll give it a try on the next one I have tried a few other brands, including the new stuff from Magiuars (Scratch X2). I find that Scratch Doctor is the better one for what I do. Just remember to do only small surfaces at a time, use small dabs and don't let this stuff sit on the finish too long, it may start to "penetrate" the finish and soften it. ![]() Good luck with it! Pat Thanks for the tips! |
