It is currently Fri Aug 15, 2025 3:28 pm
 Post subject: Truss Rod Help
PostPosted: Wed May 19, 2010 8:16 am
First name: Tim
Last Name: Warren
State: Ok
Zip/Postal Code: 73020
Can anyone tell me what kind of truss rod this neck is cut for. I tried to contact the guy I bought it from but the number is disconnected.
It's about .262 wide and .400 deep and the slot is .385 wide and .475 deep.
Tim
 Post subject: Re: Truss Rod Help
PostPosted: Wed May 19, 2010 12:00 pm
Last Name: Abercrombie
Tim-
If you check the supply places (LMII,StewMac,Allied) you should be able to find a rod that fits .
You can always glue in some shims into the wider area of the slot if necessary- some rods use an even-width slot all the way.
The slot is generally a bit deeper than the rod, to allow for a cover strip of some kind.
Here's a chart from LMII...
PostPosted: Wed May 19, 2010 1:01 pm
That looks like a Martin neck to me, correct? If so, you should get a Martin rod.
PostPosted: Wed May 19, 2010 1:04 pm
Last Name: Wood
City: Chester Springs
State: PA
Zip/Postal Code: 19425
I agree with Steve. That looks like a Martin neck routed for their two way truss rod.
Chris.
PostPosted: Wed May 19, 2010 2:22 pm
First name: Tim
Last Name: Warren
State: Ok
Yep it is the 2 way truss rod Martin is using now. They said they started using it about 3 years ago. Thanks for the help
Tim
PostPosted: Thu May 20, 2010 6:53 am
This is a Martin 2 way truss rod style neck . here is a link to a truss rod . I do stock them . http://www.bluescreekguitars.com/catalo ... cts_id=128
thanks
john
PostPosted: Thu May 20, 2010 7:03 am
First name: Tim
Last Name: Warren
State: Ok
Thanks John, if I had known you stocked them I would have bought it from you but have already ordered from Martin.
Tim
Tim
Users browsing this forum: stumblin, wbergman and 18 guests
