Show me your fretboards! http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=27617 |
Page 1 of 2 |
Author: | Eric Hoffer [ Sat May 29, 2010 12:25 pm ] |
Post subject: | Show me your fretboards! |
Just looking for some ideas for fret position markers. Materials, designs, etc...I would like to stay relatively simple (no ornate inlays). Also, I am thinking about inlaying wood into the fretboard but I am worried as it may expand and contract differently that the board itself because of the lack of a finish. Let me know what you think. Upload some pics if you like! lets see some fretboards! ![]() -Eric |
Author: | Brock Poling [ Sat May 29, 2010 12:36 pm ] |
Post subject: | Re: Show me your fretboards! |
Wood looks nice gong in, but it doesn't wear very well. The lighter inlaid woods end up looking grungy pretty fast. Have you considered recon stone? It comes in about a billion colors |
Author: | Eric Hoffer [ Sat May 29, 2010 1:36 pm ] |
never heard of it, I will have to check it out. I was also thinking of corian... |
Author: | Brock Poling [ Sat May 29, 2010 1:54 pm ] |
You can find it at jewler's supply houses. Rio Grande IIRC has a bunch of it. |
Author: | Hank Mauel [ Sat May 29, 2010 3:50 pm ] |
Here are a couple...one with doves flying down the fretboard and the other with swallows flying up/down to cherry tree inlay at 10-14th frets. |
Author: | Ken Franklin [ Sun May 30, 2010 1:00 am ] |
Here are some martini glass inspired red abalone markers I made once. |
Author: | Haans [ Sun May 30, 2010 8:05 am ] |
As I've always considered the fretboard a working surface that has to be re-fretted, planed, sanded, I don't go farther than dots and diamonds. Most folks tell me that vines, tress of life, all that stuff only confuses them on the fretboard anyway. |
Author: | Stuart Gort [ Sun May 30, 2010 9:48 am ] |
viewtopic.php?f=10106&t=25575 Fretboards, tooling, and such. |
Author: | Alain Moisan [ Sun May 30, 2010 12:20 pm ] |
Brock Poling wrote: Wood looks nice gong in, but it doesn't wear very well. The lighter inlaid woods end up looking grungy pretty fast. Have you considered recon stone? It comes in about a billion colors I use 1/4" maple dots. Sealing them with CA does a pretty good job at making sure they don't get too dirty. |
Author: | Eric Hoffer [ Sun May 30, 2010 5:15 pm ] |
How do you seal the maple without getting it on the fb? Does the CA wick into the maple without leaving behind a high spot? |
Author: | Alain Moisan [ Sun May 30, 2010 6:18 pm ] |
Eric Hoffer wrote: How do you seal the maple without getting it on the fb? Does the CA wick into the maple without leaving behind a high spot? I do get some (just a little) on the fretboard, but I scrape/sand it all off. I do this twice before final sanding. Once finished, there is no trace of the CA around the maple dots. Of course, you still have to be cautious when you apply the CA and not spill too much of it outside the marker dots. |
Author: | brenbrenCT [ Tue Jun 01, 2010 10:50 am ] |
Alain Moisan wrote: Eric Hoffer wrote: How do you seal the maple without getting it on the fb? Does the CA wick into the maple without leaving behind a high spot? I do get some (just a little) on the fretboard, but I scrape/sand it all off. I do this twice before final sanding. Once finished, there is no trace of the CA around the maple dots. Of course, you still have to be cautious when you apply the CA and not spill too much of it outside the marker dots. alan, do you tap dowels in then flush cut, or cut plugs? my first guitar i did with dowels and obviously the endgrain got a bit gunky. Didn't seal them because i didn't think of it, so they got gunked up. thanks |
Author: | Alain Moisan [ Tue Jun 01, 2010 12:12 pm ] |
brenbrenCT wrote: alan, do you tap dowels in then flush cut, or cut plugs? my first guitar i did with dowels and obviously the endgrain got a bit gunky. Didn't seal them because i didn't think of it, so they got gunked up. thanks I use a plug cutter for the exact purpose of not wanting end grain markers. Plus, the conical shape of the plugs make it easy to push them in place. I usually make them about 3/16"-1/4" tall. I press them in using a vise (after putting some CA glue in the holes) and fush cut watever is left proud if the fretboard surface. |
Author: | Darryl Young [ Tue Jun 01, 2010 12:28 pm ] |
Hank, Would you mind posting a close up picture of the swallows if you have one? I've wondered if any one had a purple martin inlay.....maybe a generic swallow would be close enough. Did you cut the inlays yourself or purchase them? Thanks! |
Author: | Hank Mauel [ Tue Jun 01, 2010 12:34 pm ] |
Haans wrote: Most folks tell me that vines, tress of life, all that stuff only confuses them on the fretboard anyway. Tell them not to look at the fingerboard while playing. ![]() If Doc Watson can play that way, so can they! ![]() |
Author: | Marc Lupien [ Thu Jun 03, 2010 2:05 pm ] |
Here is a photo of a laminated fretboard (honduras rosewood and purpleheart. So far no problem with schinkage... |
Author: | RQuinn [ Thu Jun 03, 2010 8:51 pm ] |
working on numero uno, flowers marking the 12th and 9th frets....there will be frets soon.... |
Author: | Haans [ Fri Jun 04, 2010 7:54 am ] |
Hank Mauel wrote: Haans wrote: Most folks tell me that vines, tress of life, all that stuff only confuses them on the fretboard anyway. Tell them not to look at the fingerboard while playing. ![]() If Doc Watson can play that way, so can they! ![]() Then why have anything at all? Like I said, it's a working surface...and they are called "position markers". ![]() |
Author: | Laurent Brondel [ Fri Jun 04, 2010 8:33 am ] |
I'm with Haans on this one, I think inlays are distracting and hard to pull off without looking gaudy. But I'm not an inlay guy so… I only put dots when requested, otherwise side dots are more than enough. I usually frame the fretboard with one single curly maple line, two maximum. |
Author: | Eric Hoffer [ Fri Jun 04, 2010 9:26 am ] |
I completely agree with you. I am not a fan of the ornate inlays either. I am planning on doing something which incorporates the side dots and front position markers into one element. Maybe just a strait...say 1/8" wide, channel that comes right off the side of the board and extends about 3/4" towards the center. (hope this makes sense) I have some corian samples that I took from Home depot to use. They are white with some very subtle bluish specks. -Eric |
Author: | Laurent Brondel [ Fri Jun 04, 2010 12:24 pm ] |
Have you checked Michael Bashkin website? I think he does something similar to what you describe, quite stunning and elegant work. |
Author: | Haans [ Fri Jun 04, 2010 12:48 pm ] |
Laurent Brondel wrote: ...I think inlays are distracting and hard to pull off without looking gaudy... Ya mean like this?!? Let's see, what fret am I on? ![]() Lovely it is, but where'd the ebony go? How'd you like to plane the F/B and re-fret this? |
Author: | Daniel Minard [ Fri Jun 04, 2010 1:49 pm ] |
I think you'd be SANDING that fretboard if it needed to be levelled & re-fretted. Still, it'd be scary. |
Author: | sttelnoj [ Fri Jun 04, 2010 2:35 pm ] |
a blank fingerboard says to me. . .i'm looking with my ears, and who cares what my guitar looks like (within reason folks). its about the sound i make and i know what position my fingers are in. nothing can add to the beauty of a jet black ebony board. im not anti inlay however. my friend keeps moaning that my guitars don't have dots. if you play a guitar regularly you dont need em in my humblest opinion. side dots are ok by me. |
Author: | Arnt Rian [ Fri Jun 04, 2010 2:44 pm ] |
If I get to decide, I make 'em with side dots only. I've done some vines and things, but that stuff is really not my cup of tea ![]() |
