It is currently Sat Aug 16, 2025 9:04 pm
 Post subject: Neck shim
PostPosted: Fri Jun 25, 2010 2:38 pm
Last Name: Charnock
Country: UK
After I get the binding done I'll fit the neck.
At the moment the top of the neck is slightly below the surface of the top and isn't that tight.
Shall I shim the sides of the dovetail on the tenon ?
 Post subject: Re: Neck shim
PostPosted: Fri Jun 25, 2010 3:08 pm
I make this shim dry and then glue it to the block when I glue in the neck . so I do it all at once
