It is currently Sun Aug 17, 2025 6:55 pm
PostPosted: Wed Jun 30, 2010 3:26 pm
Last Name: Charnock
Country: UK
Hi
Many of you recommend coating the top with shellac before routing the rosette, do I shellac the whole top or just the area I am cutting ?
Could I shellac both sides completely and would this be beneficial ? (re long thread recently posted about shellac on the insides)
I will be sanding the top and back to a final finish after the rosette and sound hole is cut.
PostPosted: Wed Jun 30, 2010 3:38 pm
First name: Tom
Last Name: West
State: Nova Scotia
John: Just in the area of the rosette. It helps to prevent tearing at the edge of the cut out.
Tom
PostPosted: Wed Jun 30, 2010 3:41 pm
You can do the whole top. It's not a bad way to keep the top from getting stained and dirty. You can either wipe if off with alcohol, or sand it off in a few strokes. It does not penetrate very deep.
PostPosted: Wed Jun 30, 2010 3:59 pm
First name: Glenn
Last Name: LaSalle
City: Saint Petersburg
Silly question: When you say coating with shellac, what specific shellac are you talking about (and where do I buy it? are we talking about shellac flakes, etc, or a "canned" shellac?
Glenn
PostPosted: Wed Jun 30, 2010 4:03 pm
Last Name: Charnock
Country: UK
This is stuff I was intending to use
http://www.axminster.co.uk/liberon-libe ... ricing=inc
PostPosted: Wed Jun 30, 2010 4:58 pm
That should work fine. I use about a 2lb cut.
PostPosted: Thu Jul 01, 2010 9:31 am
hmm I never heard this one before but I will give it a try since I almost always get some tear out. The method I use now to help with tear out is to use a razor knife circle cutter to score the lines before routing.
PostPosted: Fri Jul 02, 2010 5:54 am
Lacquer works fine too. Just dip a rag and rub it in. A couple coats is insurance especially with softer spruces like Engelmann. Important part is to let it completely dry hard.
Users browsing this forum: Chris Ide and 24 guests
