router bit for 20/20 BW purfling for rosette
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=28171
Author:  AlexanderLou3 [ Sun Jul 11, 2010 11:53 pm ]
Post subject:  router bit for 20/20 BW purfling for rosette
I'm sure it's been covered before but searches also turn up results for b/w/b, 20/20/20 which is discussed much more and easily done with a 1/16th" bit. Anyone using a .020/.020 around the rosette? I need to find a router bit!
The purling is .04"
Stewmac has a 3/64th" router bit that would be the closest to working.
3/64th = .0.046875"
It seems the extra .0068 wouldn't even be noticable, especially considering the inconsistencies that purfling strips are, and even bits themselves it seems. I'm sure once glue is added and it swells it will be a perfect fit but comments and reassurance would be great! Thanks!!!
Author:  Steve Saville [ Mon Jul 12, 2010 1:01 am ]
Post subject:  Re: router bit for 20/20 BW purfling for rosette
I use micro mill bits like these -
http://cgi.ebay.com/10-Micro-Solid-Carb ... 23085eb38c
http://cgi.ebay.com/Carbide-Micro-2-Flu ... 5d29e9b5d7
Author:  Dave Fifield [ Mon Jul 12, 2010 1:19 am ]
I would use a normal 1/32" bit and take two passes at it, moving the bit out by 10 mil for the second pass. This will make a channel about 41mil wide, which will allow easy fitting of the purfling.
Cheers,
Dave F.
Author:  bluescreek [ Mon Jul 12, 2010 6:41 am ]
http://bqtool.com/cart/index.php?cPath= ... 54cdddab21
I use the square end mills. They also have a .020 mill that you need to call to order. For rosetting I use a modified circle cutter that uses my die grinders. Todd Stock Made one from Lexan , he should post that picture , it is not that difficult to make and workds very well.
Author:  Terry Stowell [ Mon Jul 12, 2010 7:57 am ]
here ya go...
Author:  Mike OMelia [ Mon Jul 12, 2010 3:21 pm ]
Terry Stowell wrote:
here ya go...
I SO got to get one of those air dive pencil routers!!! Been high on my acquisition list for sometime.
Author:  SteveSmith [ Mon Jul 12, 2010 4:25 pm ]
here ya go...
Me too.
