tape tabs on sides to be bent http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=28212 |
Author: | Greenman [ Wed Jul 14, 2010 4:35 pm ] |
Post subject: | tape tabs on sides to be bent |
Author: | Michael Smith [ Wed Jul 14, 2010 4:40 pm ] |
Post subject: | Re: tape tabs on sides to be bent |
I mark with tape, slip it into the bender, measure, pull tape and reinsert. |
Author: | TonyKarol [ Wed Jul 14, 2010 4:44 pm ] |
If you wrap your wood in foil or whatever, put the tape on that .... it never touches the wood. |
Author: | Alain Moisan [ Wed Jul 14, 2010 5:16 pm ] |
I tape the bindings to the sides with green masking tape, directly on the wood. Never had a problem. |
Author: | segovia [ Wed Jul 14, 2010 5:18 pm ] |
Hi Can you post a link to the video ? J |
Author: | bluescreek [ Thu Jul 15, 2010 8:17 am ] |
I used to use chalk to mark my position but now I have a story pole. This secret will be out on the Open House this Sat. There should be a video soon. |
Author: | Mark Groza [ Thu Jul 15, 2010 8:26 am ] |
Another way is to drill a small 1/16" hole at the position and insert a toothpick to mark the spot. It's easily seen and no glue or tape are required. ![]() |
Author: | woody b [ Fri Jul 16, 2010 8:21 pm ] |
I just mark the waist with a pencil..........then remove the mark with an eraser. |
Author: | JJ Donohue [ Sun Jul 18, 2010 8:12 am ] |
I mark the side with chalk and tear a small slit in the craft paper to allow the mark to be visible. I also mark the UB and LB borders and confirm that they line up appropriately in the form as well. |
Author: | segovia [ Sun Jul 18, 2010 10:16 am ] |
bluescreek wrote: I used to use chalk to mark my position but now I have a story pole. This secret will be out on the Open House this Sat. There should be a video soon. [code][/code] Hi John I can't wait "story pole" ???? John |
