Adjustable Fretboard Taper Jig--TS or Router T.??? http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=28297 |
Author: | Miketobey [ Wed Jul 21, 2010 1:09 pm ] |
Post subject: | Adjustable Fretboard Taper Jig--TS or Router T.??? |
I checked the archives and struck out. Does anyone have a jig that is adjustable for tapering? I am doing some FB's for guitars whose precise neck dimensions are fixed- at most I would have 1/64th" per side to play with, and ideally, 1/128th for 64th total. The FB's will be bound. If I am going to build a long-lasting and versatile jig, I'd like to shoot for adjustable. I'm having trouble visualizing a design in my mind- usually that does not happen. All suggestions welcomed.mt |
Author: | ChuckG [ Wed Jul 21, 2010 1:40 pm ] |
Post subject: | Re: Adjustable Fretboard Taper Jig--TS or Router T.??? |
I use this: --- |
Author: | Dave Stewart [ Wed Jul 21, 2010 1:48 pm ] |
This is the one I use on the tablesaw. The T'saw fence is set jig width. The long jig fence is set to 22nd fret width. The upper tab (1st cut, slots up) is set to halfway between the nut width and 22nd fret width. The lower tab (2nd cut, slots down) is set to nut width. Works very well if you need a fully adjustable jig. |
Author: | Terence Kennedy [ Wed Jul 21, 2010 2:53 pm ] |
That's a good way to go. I believe Tony Karol described a similar jig a couple of years ago on this forum. It's how I've always done it and it works well. |
Author: | TonyKarol [ Wed Jul 21, 2010 4:45 pm ] |
Yep .. thats one of mine (or a copy of it) .... I got so tired of changing it from whatever its set at to do a std 1 3/4 nut I made a second one thats always set for that size ... |
Author: | Dave Stewart [ Wed Jul 21, 2010 6:05 pm ] |
Yeah, I was pretty sure I didn't think of it! ![]() |
Author: | woody b [ Wed Jul 21, 2010 7:29 pm ] |
I don't have a "standard" width or taper. There's no stop on mine. I just measure to position the board. Yes, once I got the ends swapped and had a board that was narrow at the body, and wide at the nut. ![]() ![]() ![]() |
Author: | ChuckG [ Thu Jul 22, 2010 8:25 am ] |
Woody - you mean like this? ![]() |
