sheet metal radius dish/magnetic clamping http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=28967 |
Author: | Tai Fu [ Wed Sep 08, 2010 2:06 pm ] |
Post subject: | sheet metal radius dish/magnetic clamping |
I was wondering, anyone thought of making a radius dish using sheet metal by making ribs out of wood or metal, then screwing a strong but mildly stiff but flexible sheet metal such as spring steel to those ribs, to allow for changes in radius, or when steel is used as the base material strong magnets can be placed on braces in order to clamp it... |
Author: | Brock Poling [ Thu Sep 09, 2010 7:27 am ] |
Post subject: | Re: sheet metal radius dish/magnetic clamping |
I think this is a clever idea. I have used magnets quite a bit in various guitar making tasks... but I sometimes find that it is a solution in search of a problem. I have tried various glue up methods and I always return to a simple go bar deck. It is simple, fast and flexible. |
Author: | Bob Garrish [ Thu Sep 09, 2010 11:19 am ] |
Magnets for braces are tough because the strength of attraction decays quickly with distance. I think you'd need some dangerously strong magnets to have good holding power at the distance a brace top is from the metal beneath. |
Author: | Brock Poling [ Thu Sep 09, 2010 1:17 pm ] |
Well... you could make a harness with two magnets to straddle the brace and pull it into position. but again... I am not sure that there is any advantage to this vs. a go bar deck. |
Author: | npalen [ Thu Sep 09, 2010 2:36 pm ] |
Might work to drill holes and embed magnets into the MDF dish. Maybe embed two magnets with one on either side of the brace then use a hat shaped clamp over the brace to get good holding power. Could possibly establish the brace position with this method. Again, maybe a solution looking for a problem but it's fun (and good) to think outside the box on occasion. Nelson Palen |
Author: | Tai Fu [ Thu Sep 09, 2010 4:51 pm ] |
Sorry about the magnet idea.... probably not the best out there... What do you think about the wood rib/sheet metal radius dish? Could be made cheaply I think and the remaining space can then be filled with expanding foam for additional support. |
Author: | Dave Fifield [ Thu Sep 09, 2010 7:29 pm ] |
Methinks a routed out piece of 1" thick MDF is much cheaper than any fancy metal fabrication.... Dave F. |
Author: | Tai Fu [ Thu Sep 09, 2010 9:35 pm ] |
Dave Fifield wrote: Methinks a routed out piece of 1" thick MDF is much cheaper than any fancy metal fabrication.... Dave F. It's not so much the price of MDF, but the fabrication process itself is too messy... and time consuming because you would have to find ways to rotate the router or wood. Also MDF is really toxic... |
Author: | Chris Paulick [ Fri Sep 10, 2010 3:52 am ] |
I don't have a mess when I make my dishes. People have made dishes with 1/4" hard board and ribs too. I really don't see an advantage to using metal as it might dent easier and even rust. I know John Hall is using some kind of backer board instead of MDF that is more stable. Perhaps finding another material might be better but MDF is pretty cheap. |
Author: | Dave Fifield [ Fri Sep 10, 2010 5:43 am ] |
Tai Fu wrote: Dave Fifield wrote: Methinks a routed out piece of 1" thick MDF is much cheaper than any fancy metal fabrication.... Dave F. It's not so much the price of MDF, but the fabrication process itself is too messy... and time consuming because you would have to find ways to rotate the router or wood. Also MDF is really toxic... Ah-ha....so have someone else make them for you - no mess in your shop - then seal them with shellac. That's what I do. Several of the OLF sponsors make them, including Shane Neifer who has a line of standard radius dishes and will make custom radius dishes for a paltry $15 more....check them out here (scroll down to nearly the bottom of the page, or click the link on the left). Good luck! Dave F. |
Author: | Chris Paulick [ Fri Sep 10, 2010 5:48 am ] |
The shipping would be pretty high for him. |
Author: | Tai Fu [ Fri Sep 10, 2010 6:08 am ] |
Dave Fifield wrote: Tai Fu wrote: Dave Fifield wrote: Methinks a routed out piece of 1" thick MDF is much cheaper than any fancy metal fabrication.... Dave F. It's not so much the price of MDF, but the fabrication process itself is too messy... and time consuming because you would have to find ways to rotate the router or wood. Also MDF is really toxic... Ah-ha....so have someone else make them for you - no mess in your shop - then seal them with shellac. That's what I do. Several of the OLF sponsors make them, including Shane Neifer who has a line of standard radius dishes and will make custom radius dishes for a paltry $15 more....check them out here (scroll down to nearly the bottom of the page, or click the link on the left). Good luck! Dave F. The problem then is that the prices the sponsors charge are really high, and the shipping makes it very expensive. I am planning on moving to Europe soon, I hope there are sponsors making it there. |
Author: | Bob Garrish [ Fri Sep 10, 2010 11:46 am ] |
If it's cost prohibitive, there are other options. There are people making real flat tops (Kevin Ryan, Jim Olson, Mario Proulx) who seem to be doing fine with it according to their wait lists and reputations, so that covers one dish. Mario used a chunk of a domed car hood for his back 'radius dish' for many years. |
