It is currently Mon Aug 18, 2025 10:57 pm
PostPosted: Sun Sep 12, 2010 10:09 am
.100 thick for me.
PostPosted: Sun Sep 12, 2010 10:27 am
This depends on what I am working on. A slot head may have a thicker veneer than a pan head. For me the rule of thumb is .060 for pan head and up to .100 on slot heads.
PostPosted: Sun Sep 12, 2010 10:34 am
.10" for me.
PostPosted: Sun Sep 12, 2010 10:38 am
Country: Romania
Mine (classical) are 0.085, usually plus a sheet or two of veneer.
Build log
PostPosted: Sun Sep 12, 2010 10:59 am
60-80 thou, plus veneer lines ....
PostPosted: Sun Sep 12, 2010 11:10 am
.062", except when not.
PostPosted: Sun Sep 12, 2010 11:36 am
City: Jacksonville
Good question Chris....I'm watchin this one.... Eat Drink
PostPosted: Sun Sep 12, 2010 11:42 am
First name: Tom
Last Name: West
State: Nova Scotia
Generally .080 to .100 or so. Quite often this is just eyeballed. Nothing much here that is fussy in my mind.
Tom
PostPosted: Sun Sep 12, 2010 11:46 am
.065" to .080" in most cases for a non slotted peg head. I tend to bookmatch my headplates also.
Chuck
PostPosted: Sun Sep 12, 2010 1:49 pm
Mine are 0.1 also.
Say, does anyone here taper the peghead?
PostPosted: Sun Sep 12, 2010 5:37 pm
When planning on thickness it is a good idea to check the tuners you are using. I have seen more than 1 guitar where the builder missed that part and then the post was too short and the threaded ferrule didn't hold. In the case of Martin , they use .0625
PostPosted: Sun Sep 12, 2010 5:55 pm
Yep, You never noticed? I do about 1/16" like Chris V.
PostPosted: Sun Sep 12, 2010 7:01 pm
I know what You do, Steve. I just completely discount that... KIDDING!!! Thanks for the heads up on that...
PostPosted: Mon Sep 13, 2010 6:09 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I have probably cut a couple thousand head plates, mostly 'leftovers' from cutting backs and sides. I like to sell them as thick as possible, because it gives the buyer more options, and thicker wood is less delicate to ship. I tend to leave them thick until I am ready to use them. Most of the headplates I use are Martin style (1/16" nominal). I have done a few tapered thickness pegheads, but most of my solid heads these days are a uniform 9/16".
You could always ask the seller to thickness sand the head plates to your specification.
PostPosted: Mon Sep 13, 2010 6:52 pm
[quote="SteveCourtright"]Mine are 0.1 also.
Only on mandolins. Overlay varies from 1/16-1/8" depending on whether it's bound and whether it's laminated on the side.
PostPosted: Tue Sep 14, 2010 10:10 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Yea... I decided to order some guitar woods which also includes enough for a headplate (since a standard guitar side or back doesn't really provide enough wood to make a complete headplate unless I am making a ukulele or something), and the supplier gives me a block of (Indian Rose)wood around 3" wide, 7" long, and around 1" thick! I would have said "hey thank you!" except I have no way of resawing... and I am not planing that entire block to 1/8" so I can use it as a headplate!
Typhoon Guitars
PostPosted: Tue Sep 14, 2010 12:23 pm
Typically 3/32 for me if I do the pinstripe designs it will bring it up to 1/8.
Users browsing this forum: Dmaxwell, Terence Kennedy and 34 guests
