It is currently Mon Aug 18, 2025 10:56 pm
 Post subject: Neck Length
PostPosted: Wed Sep 15, 2010 4:44 pm
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
I'm building a baritone ukulele. I would like to make the neck about 1.5 inches longer than my plan. If I use the fret spacing calculator on the stumac website is this a problem?
http://goatrockukulele.com
 Post subject: Re: Neck Length
PostPosted: Wed Sep 15, 2010 5:11 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
For sure, you can make the scale you want... but I would suggest you to draw it down on paper, to see if all is gonna bo okay with the bridge, soundhole, etc...
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Wed Sep 15, 2010 5:44 pm
As Francis says, you'll have to draw it out on paper. Uke's are small so you don't have a lot of room to move the bridge around. My Baritone Uke plan uses an 18 1/2" scale with a 14th fret joint. If I add 1 1/2" and make it a 20" scale and use a 16th fret joint, the bridge moves about 1/4" towards the tail block.
Users browsing this forum: Dmaxwell, Terence Kennedy and 37 guests
