Hairline crack in sitka spruce
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=29169
Author:  weslewis [ Tue Sep 21, 2010 8:37 pm ]
Post subject:  Hairline crack in sitka spruce
I have a good set of sitka spruce with a tight ring count that has a hairline crack about an inch long..I thought I would shellac the area and hit it with some thin ca....is that acceptable ??????
Author:  Alan [ Wed Sep 22, 2010 6:55 am ]
Post subject:  Re: Hairline crack in sitka spruce
My experience is that CA will cause a yellow stain on spruce.
Author:  Elman Concepcion [ Wed Sep 22, 2010 7:56 am ]
Don't add shellac.
Where is the Hairline and how long?
Does it terminate at the edge or not?
Can you flex and see it open on both sides?
Author:  bluescreek [ Wed Sep 22, 2010 8:16 am ]
this is an easy repair . No on the shellac as stated prior and no on the ca . Tite bond or hot hide glue will work. No need to make it harder than it is .
Author:  weslewis [ Wed Sep 22, 2010 3:14 pm ]
the crack is in lower bout area..its a thick piece of sitka, dropped and hit on one side ..I steamed it out and saw it had just a very small hair line crack...how would I use titebone..just kind of force it into the small crack as I flex it?????
thanks for the replys
