It is currently Tue Aug 19, 2025 11:33 am
 Post subject: FB & bridge length
PostPosted: Wed Oct 06, 2010 8:08 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
I am cutting some classical FB & Bridges to length to send to someone and in my indeavor to be precise I would like to know the maximum length a classical FB & bridge would be exactly, (because I know nothing about classics). For example, on my M OOO the FB is 17.875
Mike McNerney
 Post subject: Re: FB & bridge length
PostPosted: Wed Oct 06, 2010 11:11 am
Last Name: Abercrombie
Mike-
Unless it's a 'surprise' gift, it's probably best to ask the recipient, as the FB length will depend on scale length, and # of frets (some classicals have an 'extra' fret (or two) hanging into the soundhole). Since the end of the classical FB is generally curved, I find I need a bit extra length so I can 'zero in' on the correct dimension as I fit the board.
Bridge length is generally in the 190mm range, but again it's probably best to ask.
If you have plenty of wood, you could just use the dimensions from one of the commercial suppliers, I suppose.
I'd be happy to check a few of my guitars if you need more info.
PostPosted: Wed Oct 06, 2010 11:25 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
Thanks I got some numbers
MM
Mike McNerney
