Assistance please - seams appearing in back http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=29687 |
Author: | Corky Long [ Thu Oct 28, 2010 9:17 am ] |
Post subject: | Assistance please - seams appearing in back |
I glued my back together using hide glue, and I thought it was a very tight join - very sharp planes, no light with candling etc. After finishing (no pore filling - Pau Ferro) with KTM 9, and sanding and buffing, the back seam is starting to show. (a very fine indentation along the seam) Is this a function of the finish that I've used? Some reaction with the hide glue? I'd really be surprised if it's a poor join - I've improved my technique over the last 8 guitars - thought I had that licked. Thanks. |
Author: | TonyKarol [ Thu Oct 28, 2010 9:21 am ] |
Post subject: | Re: Assistance please - seams appearing in back |
Are you buffing on a wheel .. sometimes the heat generated from buffing will cause finish to sink .. into things like seams and pores ... a light wet sand, then polish by hand might do it. |
Author: | Mike Collins [ Fri Oct 29, 2010 1:51 pm ] |
Corky; Did you use any sealer? How many coats of finish? How long did you let it cure before sanding & buffing? It still could be a slight gap in the joint. fill it with more finish and let it dry for a few weeks before leveling! Mikey ![]() |
Author: | dberkowitz [ Fri Oct 29, 2010 4:57 pm ] |
What kind of glue did you use for your back joint. If you used Titebond, its very likely that that is your problem. Titebond is relatively soft. Try LMI's white glue, which is harder and less prone to movement. |
Author: | Jim Watts [ Fri Oct 29, 2010 5:35 pm ] |
I inlay my back strips vs. sandwiching them in and use epoxy in order to avoid this very thing. |
Author: | mhammond [ Fri Oct 29, 2010 10:59 pm ] |
Corky: I have noticed the same thing, however I feel its protruding rather than sinking. I surmised that the hide glue is swelling from the moisture (water) in the KTM9. I have not found a cure for the problem yet, but the good thing is that it will lay down in a week or two. After level sanding and buffing it will disappear unless your gap is not as tight as it should be. Have courage, stay the course........ Mikey P.S. After re-reading your post maybe you level sanded before it shrank back and now it shrank back to a lower level? ![]() |
Author: | Pat Hawley [ Sat Oct 30, 2010 9:30 pm ] |
I had this also with guitars I finished with KTM-9. One year I went to the guitar show in Montreal and specifically sought out guitars finished with KTM-9 and checked some seams. Same thing. So I wouldn't blame myself if I were you..... Pat |
Author: | Mark Fogleman [ Sun Oct 31, 2010 7:31 am ] |
Pat Hawley wrote: I had this also with guitars I finished with KTM-9. One year I went to the guitar show in Montreal and specifically sought out guitars finished with KTM-9 and checked some seams. Same thing. So I wouldn't blame myself if I were you..... Pat Sorry Corky for the hijack but inquiring minds... Pat, Any similarity on the type of adhesive used in your survey or do you think this is a KTM-9 thing across the board and it needs more time to set up before levelling? Anyone having similar issues with other waterbased finishes? EM6000? |
Author: | Corky Long [ Mon Nov 01, 2010 3:32 pm ] |
Mike Collins wrote: Corky; Did you use any sealer? How many coats of finish? How long did you let it cure before sanding & buffing? It still could be a slight gap in the joint. fill it with more finish and let it dry for a few weeks before leveling! Mikey ![]() Mike - I filled the grain with Zpoxy (even though it didn't really need it - Pau Ferro) Coats of finish....quite a few (over a dozen) although my crappy HVLP spray gun lays it on pretty unevenly Time of cure....aha - yeah that may be the issue. I was in a hurry - only a couple of weeks. But even so, if it was Others asked what glue - hot hide glue for the back seam (with no center strip) Thanks - Corky |
Author: | Mike Collins [ Mon Nov 01, 2010 6:05 pm ] |
Corky; I do not like the "dipped in plastic" look . I want my guitars to have some small pores showing. Looks like real wood to me that way ! BUT- I find I can not rush a finish. After final sanding(you can dampen the wood)then sand with 220 again. This will get rid of most if not all raised grain. I spray a coat of shellac. then fill with waterbase sealer. This can be sprayed on our wiped on. Spraying is the way to go -it is much more level & has a more consistant thickness . use 2 to 4 coats. Let cure for a week and then sand with 320 and do your final coats. Let cure for a week (more if you use a retarder). The wet sand & buff. have you figured what your going to build with that nice set of BRAZZIILLION?? Mike |
Author: | Corky Long [ Wed Dec 08, 2010 9:18 am ] |
Thanks, Mike, I didn't see your response until now - useful to do a review or "search my posts" - need to remember that. I've never used sealer - have always used pore filler (zpoxy these days) then sometimes a coat of shellac. I'll have to give that a try. I'll follow your process. As for the set of Brazilian, I don't know yet. I've got a couple of sets that I've been holding onto until I think I'm ready for them. I think I've got at least a half dozen more guitars to build before I want to take that on. In the meantime, I've got some really nice Amazon Rosewood that is almost indistinguishable from the Brazilian I have. I'll keep using that. Have a great holiday! |
