Cutting wood binding
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=29879
Author:  Greenman [ Thu Nov 11, 2010 8:39 pm ]
Post subject:  Cutting wood binding
I have a couple guitars going that I want to put wood binding on. I would like to cut my own binding as I have alot of scrap figured wood. What is the process to get clean sides for the binding? I would like to here what others process is and the pros and cons. Thanks :mrgreen:
Author:  meddlingfool [ Thu Nov 11, 2010 8:41 pm ]
Post subject:  Re: Cutting wood binding
I use my fretsltting blade, a zero clearance insert, and a featherboard on the topside.
Author:  Mark Maquillan [ Thu Nov 11, 2010 8:51 pm ]
I use a Freud 7 1/4 blade on my table saw. Works great.
Author:  clutch [ Thu Nov 11, 2010 8:54 pm ]
I cut on the table saw, then smooth with a thickness sander.
Don
Author:  Michael Smith [ Thu Nov 11, 2010 9:35 pm ]
I cut to a little over 1/4 inch, Then drum sand to desired height, then rip strips a little over desired thickness then drum sand to desired thickness. I find I can pur 5 or 6 thru the sander at a time.
Author:  Alexandru Marian [ Fri Nov 12, 2010 3:14 am ]
There was an informative and long topic about this not too long ago, worth a search.
