It is currently Tue Aug 19, 2025 10:25 pm
 Post subject: Your neck thickness
PostPosted: Thu Nov 11, 2010 4:40 pm
First name: Jeff
Last Name: Hewitt
Zip/Postal Code: 37312
Just curious as to what neck thickness you aim for on your steel strings....at the 1st & 9th?
 Post subject: Re: Your neck thickness
PostPosted: Thu Nov 11, 2010 7:28 pm
If it's up to me, I like 55/64" (or you could say a 64th under 7/8") at 1st fret and 61/64" at 9th
Chuck
PostPosted: Thu Nov 11, 2010 8:01 pm
.850 @#1... .900@ #9
PostPosted: Thu Nov 11, 2010 8:31 pm
21mm & 24mm
PostPosted: Thu Nov 11, 2010 8:36 pm
First name: Al
Last Name: Darned
I always find a 15 1/2 a bit tight on the throat, really bugs me, so I'll always go with a 16.
If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason. - Jack Handey
PostPosted: Thu Nov 11, 2010 8:42 pm
Last Name: A
I find 17 is nice but 17 1/2 is better. Sometimes a 17 fits as good as a 17 1/2 - too bad that now you find some that are just marked L or XL and there is no real number. Too bad the youngins will probably not learn how to a tie a Windsor.
PostPosted: Thu Nov 11, 2010 8:55 pm
First name: duh
Last Name: Padma
16 and 17 1/2 ...gees you dudes must be built like a horse...but then me just a little guy with at 14 1/2. and about the younguns not knowing nothin about a Windsor knot... me know a lotta old timers can't get the noose right. nothin but nothin beats pure silk in a double Windsor.
and for you that don't know what we talking about...a tee shirt with a painted on tie is right up yer ally.
PostPosted: Thu Nov 11, 2010 9:00 pm
Depends on the customer's request, but if nothing is mentioned, I aim for 22-23ish mm, throughout the entire neck.
Alain Moisan
(Now building just for fun!)
PostPosted: Fri Nov 12, 2010 8:53 am
First name: Kent
Last Name: Bailey
City: Florissant
State: Colorado
Zip/Postal Code: 80816
I like a shallow neck for feel....BUT my biggest issue (as a player) is the standard specs on width to be the most annoying. I prefer a wider fretboard for a SS than what standards SS makers have embraced.
KB
Wood Creations by Kent A. Bailey
EXCELLENCE IN SCULPTURE, CARVING, LUTHIER, ARCHITECTURAL MILLWORK AND DESIGN
http://www.kabart.com
PostPosted: Fri Nov 12, 2010 9:21 am
Customer dependant, but usually between .800 and .820 at the first C shape, add 20-40 for a soft V), and then add to that 60 to 100 for the 10th fret.
I bought some neck templates from Tracy, and it amazed me how thick some of the Martins are 860 and 872 (although teh 30 OM was 805). A student has a '55 J50 and its .900 and 1.something ... veyr baseball bat, but narrow, adn somewhat comfy. I could get used to it.
For me personally, its 820-830, or 850 V, and then add 80 -100.
not everyones hand finds any one given neck size comfy.
PostPosted: Fri Nov 12, 2010 10:45 am
.820 - .830" at the first fret and about .080 thicker at the 8th or 9th fret.
PostPosted: Fri Nov 12, 2010 10:57 am
kinda depends on what someone wants but on our latest the specs are:
@ nut- .875
@ 5th fret- .963
@ 11th fret- 1.042
this includes a .25 thick fretboard with a 16" radius. the guitar is a 3/4 slope dread with a 22'' scale and 1.812 nut width and a lazy c profile
PostPosted: Sat Nov 13, 2010 3:52 pm
First name: Jan
Last Name: van Cappelle
City: Doorn (near Utrecht)
State: Utrecht
Country: Netherlands
Electric:
nut: 20 mm
12th fret: 22 mm
PostPosted: Sat Nov 13, 2010 3:57 pm
First name: duh
Last Name: Padma
Measurements? Scantlings, would like to help you out but...
Duh Padma builds by the seat of me pants, and the feeling in me gut or in this case me hand or the hand thats laying down the bucks.
No two the same...sorta like peoples.
blessings
duh Padma
PostPosted: Sat Nov 13, 2010 4:02 pm
Arie if you don't mind, what guage of strings are you using with that 22" scale?
PostPosted: Sat Nov 13, 2010 6:03 pm
21/22 mm C section, 22/24 mm V section and same on asymetrical section last 2 builds (these were Hot Rod truss rods and as they were deeper than previous rods had to allow a little extra meat for the back of neck) all acoustic 6 strings, 1 x OOO, 3 x OMs.
