hide glue clamp failure??? http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=30222 |
Author: | Mike Lindstrom [ Sun Dec 05, 2010 6:49 pm ] |
Post subject: | hide glue clamp failure??? |
This afternoon, I was gluing on a bridge. I was using hide glue and the LMI vacuum clamp. My craigslist vacuum pump seized up after 6 minutes. So, what do people think about the bridge. It seemed to be a perfect match dry fitting. Uniform squeeze out that had cooled and gelled. If it matters, it's bloodwood on sitka. Unless the consensus is "no way" I suppose I'll try and string it up next week and see how it went. Thanks for your thoughts. Mike |
Author: | Alexandru Marian [ Sun Dec 05, 2010 6:57 pm ] |
Post subject: | Re: hide glue clamp failure??? |
I think it might be fine. Some people attach bridges with hide just using finger pressure. I doubt many of them can keep it for more than 6 minutes ![]() |
Author: | Jim Kirby [ Sun Dec 05, 2010 7:05 pm ] |
Ditto. If the surfaces are well mated and the hide glue is properly made, a rubbed joint is adequate. |
Author: | WaddyThomson [ Sun Dec 05, 2010 8:07 pm ] |
One more, "It's going to be fine!" If it was clamped for 5 minutes it will be a good glue job. It was time to take the vacuum off and clean up the squeezeout anyway. |
Author: | Jeff Highland [ Sun Dec 05, 2010 8:14 pm ] |
I vacuum clamp for about 15 minutes, but I think that is extremely conservative. The vacuum does seem to accelerate the drying of the squeezout. As long as it's a good fit with no stress, there should be no problem Another vote for it'll be fine from me |
Author: | Mike Lindstrom [ Sun Dec 05, 2010 8:43 pm ] |
Thanks for the reassurance. I was just about to shut off the pump for clean up, when it quit. In the past, I've then reclamped for another 15-30. This was my first with HHG. I thought it'd be good but wanted to check. I do the bridges on ukes with HHG and finger pressure, but I figure SS tension makes it more of a concern. Good to know I'll have it done for xmas. Now I've got to find a new pump. Mike |
Author: | Howard Klepper [ Sun Dec 05, 2010 10:03 pm ] |
I wouldn't let it go to a customer. |
Author: | Mike Lindstrom [ Sun Dec 05, 2010 11:13 pm ] |
Thanks for the warning, Howard. Luckily, I don't have customers. This is for a relative, and they know I'm still learning. Mike |
