Homebuilt Guitar Stand for Spraying
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=30548
Author:  Darryl Young [ Sat Jan 01, 2011 3:51 pm ]
Post subject:  Homebuilt Guitar Stand for Spraying
Built a stand to hold the guitar while I sprayed the finish. It's made where you can rotate the body as needed. It clamps to a benchtop but is heavy enough to hold a guitar without being clamped in place.
For rotation, it so happened I had a 4 1/4" hole saw on-hand from another project so I used it to cut the holes. I reused the center of this cutout as the disk to rotate in the hole. The kerf of the hole saw was roughly 0.050". I had some self sticking, 1/16" thick UHMW strips that are 3/4" wide so I used that to fill the void left by the kerf and allow the body to rotate easily. Not a perfect fit but it works fine.
Here are a few pics. First a shot of the hole saw and the UHMW strip and and end shot of the stand:
A shot of the stand holding a guitar body:
Author:  Darryl Young [ Sat Jan 01, 2011 3:58 pm ]
Post subject:  Re: Homebuilt Guitar Stand for Spraying
And a few more pictures.
Closeup of the center, rotating assembly:
Another closeup of the center rotating assembly. I used the UHMW strips on the ends of the assembly to reduce drag and wear.
And an end view of the rotating disk:
Author:  WudWerkr [ Sat Jan 01, 2011 4:16 pm ]
Nice Idea ! [:Y:]
Author:  weslewis [ Sat Jan 01, 2011 5:16 pm ]
here is mine for spraying....4x4 drilled for 3/4 dowels , easily rotated for spraying
Author:  RustySP [ Sat Jan 01, 2011 5:45 pm ]
Here's my spraying fixture. I don't have a guitar to put in it because I'm always too busy building these time saving contraptions.
