It is currently Thu Aug 21, 2025 12:04 am
PostPosted: Sat Feb 12, 2011 10:45 pm
I know in the past I've seen someone demonstrate using some sort of molding plastic as a way of quickly making cauls. The plastic becomes malleable in hot water, then hardens at room temperature - so as an example, the plastic can be formed around a loose brace, then used as a clamping caul after it cools.
Does anyone know where I can get some of this? I seem to recall Stewmac carrying some if it years ago, but there's no mention of it on their site.
PostPosted: Sat Feb 12, 2011 11:10 pm
First name: Mitch
Last Name: Johnson
City: Little Falls
State: Minnesota
Zip/Postal Code: 56345
I think LMI and Stewmac sell it. Otherwise I have some dental molding that is sort of like clay that can be reheated and reformed. You heat it up and put a layer of saran wrap to protect it from sticking to whatever your forming it to. I'm assuming you can get it from a dentist office but I got mine through school. Make sure to use the saran wrap or it will stick to watever it touches.
http://www.lmii.com/CartTwo/thirdproduc ... ly+Plastic
PostPosted: Sun Feb 13, 2011 12:16 am
Thanks! I should have checked LMI, too. Google didn't do much for me.
PostPosted: Sun Feb 13, 2011 12:45 am
First name: Mark
City: Concord
My favorite store has UtilePlast in 3.5oz packs if you don't need a bucket of Friendly Plastic. Same stuff. Seriously cool store.
http://www.sciplus.com/singleItem.cfm/terms/15568
Here's some things I really like from here:
http://www.sciplus.com/singleItem.cfm/terms/11555
http://www.sciplus.com/singleItem.cfm/terms/13411
http://www.sciplus.com/singleItem.cfm/terms/12429
http://www.sciplus.com/singleItem.cfm/terms/7386
http://www.sciplus.com/singleItem.cfm/terms/9465
