It is currently Thu Aug 21, 2025 10:40 am
 Post subject: headstock angle
PostPosted: Fri Mar 18, 2011 11:18 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Hey, I was laying out the headpiece on another weiss build yesterday,
and checked the headstock angle on it, and my pattern is 7-8 degrees.
I checked the plans, and it was the same.
I searched the archives here, and only found someone saying 13 degrees,
which is what I thought it should be.
Any opinions on the angle?
I think steeper than 7-8 would be better.
 Post subject: Re: headstock angle
PostPosted: Fri Mar 18, 2011 11:51 am
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
There is no magic angle, I think.
If you don't have enough pressure on your nut, the string may buzz or me unstable in the nut slot (like electric fenders...).
If you have to much pressure, it can break the string, or make it stuck in the nut slot (wounded ones).
Also, both situations can make your string off-tune, and sound ''dead''.
Anything between 10 and 20 should be okay. (the angle of the string itself)
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Fri Mar 18, 2011 12:09 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
I use 15 for steels,11-12 for classics & slotted head steels ; 18 for Flamenco with pegs.
Mike Collins
PostPosted: Fri Mar 18, 2011 1:53 pm
Your Weissenborn has a high nut compared to a standard guitar and thus is fine with a lower headstock angle.
All that matters is having the break angle over the nut
PostPosted: Fri Mar 18, 2011 2:41 pm
First name: Chuck
Last Name: Hutchison
City: Houston
I've alwayx used 15 degree angle for my steels too.
Can I pose a question without high jacking the thread? It does relate to the question at hand.
Where you fellers suggest buying a digital protactor? I see a Wixey brand in WoodCraft catalog for $60.00, just wondering if you'uns had any other suggestions.
Hutch
PostPosted: Fri Mar 18, 2011 3:26 pm
First name: alan
City: Santa Rosa
State: ca
Thanks all.
Jeff, good point.
Didn't even think about that.
duh
I just glued in the 12 degree.
Probably go back to the 8 degree on the next one.
PostPosted: Fri Mar 18, 2011 3:29 pm
First name: Ron
Last Name: Y
I followed Todd Stocks excellent tutorial for the first Weisenborn Copy that I built and the break angle was fine (8 degrees). I'm presently in the process of building a second Weissenborn Copy using the same specs. I didn't use a table saw, I used hand saws, but the cuts are the same.
viewtopic.php?f=10102&t=14579&hilit=head+block
PostPosted: Fri Mar 18, 2011 7:46 pm
First name: alan
City: Santa Rosa
State: ca
Another great Todd Stock method.
Ron, I like the way you're back starts curving to the nut at the lower bout.
Hey, looks like another lap steeler here!
That's all I play now.
PostPosted: Fri Mar 18, 2011 9:29 pm
First name: Ron
Last Name: Y
Hi alan,
Todd also posted the Weissenborn Style Side Profile Measurements that I'm using on my current build (above photo). I was going to post a link to the side profile measurements but I can't find them in the forum archives. I pre-profiled the sides before bending. Using Todds measurements I drew the side profile in Adobe Illustrator.
I must admit that I haven't been playing too much lap style guitar lately. I built the electric lap steel in my avatar last summer but It's been in the case for about 4 months. I do plan on playing the hog Weissenborn style guitar once It's finished. I guess I'm not too crazy about electric guitars.
ron
PostPosted: Sun Mar 20, 2011 8:13 pm
Last Name: Forbes
City: Gilbert
State: Arizona
Zip/Postal Code: 85297
Most of my guitars have about a 10 degree headstock deflection. I haven't had any problems, though if you do at 7-8 degrees it's not a big deal to put some string retainers on the headstock of this guitar and next time just increase the angle.
http://www.sixgunguitars.com
