OLF Orchestra model end blocks
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=31587
Author:  cgal_1 [ Thu Mar 24, 2011 6:57 am ]
Post subject:  OLF Orchestra model end blocks
Is it better to rout the neck block before fitting it or after? If after, then should I wait until the top and back are attached or do it after the kerfing is done?
Author:  gozierdt [ Thu Mar 24, 2011 11:15 am ]
Post subject:  Re: OLF Orchestra model end blocks
+1 for Todd's answer. There are a lot of chances for mis-alignment if you route the
raw block. I've never had a problem routing after the box is closed. If you look at
Robbie O'brian's toot on YouTube you'll get a good idea how easy it's done.
Luthier Tips du Jour - Bolt on Mortise and Tenon Neck Joint
http://www.youtube.com/watch?v=yzlZvDyKnPI
