Black or white fibresheet as veneers
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=31824
Author:  RonaldD [ Tue Apr 12, 2011 8:04 am ]
Post subject:  Black or white fibresheet as veneers
Hello,
Have any of you used the black or white veneer fiber sheets for main block pattern and wheat design>
How do they stand out next to the regular wood veneers, how do they blend?
Ronald
Author:  RonaldD [ Tue Apr 12, 2011 10:21 am ]
Post subject:  Re: Black or white fibresheet as veneers
Oh I see..
It is like planing edges from cardboard; albeit stronger.
Ronald
Author:  WaddyThomson [ Tue Apr 12, 2011 10:36 am ]
I made a whole batch of wheat with the off white fiber as the white. I threw the whole batch out. It might have worked, but the fiber wanted to separate when cutting the tiny strips. It would break at the fiber lams, leaving fiber on both sides of the joint. The stuff is just not very strong. It also looked like .........well..........fiber, and not at all like wood.
If you want nice white fine line wheat, I recommend the white, natural they call it, thin, LMII veneer. Expensive? Absolutely, but it is really nice stuff and looks great. Very easy to cut, and looks very natural, IMO.
Author:  ernie [ Tue Apr 12, 2011 10:44 am ]
Hi I made the wheat strips from real veneer .6mm walnut, mahogany, and maple from veneer packets at woodcraft. I also used one piece of homemade veneer as well to complete the design. Never tried fiber, sounds like its more suitable for (health food) than luthiery ?
Author:  Laurent Brondel [ Tue Apr 12, 2011 11:36 am ]
Yeah, fibre is a bear. It tears out if cut with a table saw and prefers to be sliced with a sharp knife, which tends to be difficult if you laminate sheets together. Some fibre also tends to turn greyish when scraped, and not jet black.
Author:  Chris Ensor [ Tue Apr 12, 2011 1:10 pm ]
Any suggestions as to what to use instead of fiber for reagular only purfling strips (not marquetry) if a guy wants black (and doesn't want to make ebony strips)?
Author:  WaddyThomson [ Tue Apr 12, 2011 8:54 pm ]
Most veneer dealers have an ebonized version of something. I have used LMII, and Constantine's, and I know others have black veneers. LMII is the only one I know that sells a very thin veneer.
Author:  Mike OMelia [ Thu Apr 14, 2011 11:22 am ]
The LMI maple veneers are the way to go. For some reason, they can be difficult to laminate, I am still perfecting my technique. But the results are amazing. Fibre has it's uses, this is just not one if them. If you find the price of dyed veneers too high, and plan to do a lot of this work, you can build your own vacuum dying system for $300-$400. Then add the cost of dyes (transtint).
See Joe Woodworker's website for this project.
Author:  peterm [ Sat Apr 16, 2011 12:48 am ]
I use fiber all the times with no issues whatsoever. Mainly for neck lams and backstrap veneers. In fact I find it stronger than wood veneers. Apply a good amount of glue and give it a minute or so to soak in than clamp it...
Author:  Laurent Brondel [ Sat Apr 16, 2011 7:54 am ]
Peter is right, fibre is tough material.
For sources of excellent quality veneer (not all veneer is equal…):
http://www.wood-veneers.com/
http://www.certainlywood.com/
Author:  Burton LeGeyt [ Sat Apr 16, 2011 12:55 pm ]
I use the black fiber for most of my purfling lines and I like it. I get it in 6 x 36 sheets from Bob C. I wouldn't use anything thicker than .02 in the fiber though. At that thickness I would use wood. I have used the white and off white in the past but now I just use maple for the lighter lines, I think it always looks better than the white. I do have problems with finish sinking into the fiber lines, no matter what the finish is. I thought it might be the titebond I used to laminate the purflings together, and it might be, but I do think it is the fiber. It has never delaminated on me, just showed a very slight dip on those lines. I find the fiber much much easier to use than the dyed poplar or maple lines.
