It is currently Fri Aug 22, 2025 8:59 am
PostPosted: Wed Apr 20, 2011 11:40 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
I'm interested in try this stuff and wondering if it's possible to apply it on top
of regular shellac.
Anybody?
PostPosted: Thu Apr 21, 2011 10:14 am
First name: George
Last Name: Thomas
Run:
I have used it over non Ubeaut shellac but the initial application was pretty thin. The Ubeaut was done within a couple of days after the non-Ubeaut. It works as advertised and gets fairly hard. However should you want to do a touch up or repair after the Ubeaut hardens it is a no go. I have sprayed it and padded it on different guitars with good results except for the repair part. I have been told that on the one guitar I sprayed the finish might crackle after several years. The theory being that since there was no pressure during the application as there would be with padding it is not as dense. After one year it still looks good so we will see. If you want an unopened pint of Ubeaut cheap, send a PM.
GEO
perpetual beginner
PostPosted: Thu Apr 21, 2011 2:07 pm
First name: Jake
Last Name: Morton
City: Brookline
State: MA
Zip/Postal Code: 02445
I believe the instructions actually direct you to apply regular shellac first, and then apply the Ubeaut on top.
