It is currently Fri Aug 22, 2025 10:57 pm
 Post subject: Bracewood and Runout
PostPosted: Tue May 17, 2011 12:59 pm
Another newbie question here. How much runout/how off-quarter is acceptable for wood intended to be used as bracewood?
 Post subject: Re: Bracewood and Runout
PostPosted: Tue May 17, 2011 1:24 pm
Sure!
I found some spruce blocks that are being listed as bracewood, but it looks like they have been sawed instead of hand-split. Here is a picture of the face of the block:
And then the block would be cut/split like this for the bracewood stock:
Uploaded with ImageShack.us
I'm just wondering if that would work, or if I'd be better off getting something different.
Thanks! :)
PostPosted: Tue May 17, 2011 1:25 pm
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
I think Brace wood is one area you really want to watch out about runout, which is why the pros like to split it down before sawing or shaping. Such a small piece of wood needs the stability of continuous grain. But of course you already know that. :mrgreen:
PostPosted: Tue May 17, 2011 1:27 pm
Yep. I'm just broke, and trying to figure out how much I can get away with before it bites me in the rear end. laughing6-hehe
PostPosted: Tue May 17, 2011 1:44 pm
PappaWoodie, First off, Runout and off vertical are two entirely different issues. The pictures you have shown are certain;y a little off vertical but in y opinion not too bad. I try not to sell bracewood that is that far off vertical but from the reading I have done I wouldn't be afraid to use as is. But, for aesthetic reasons I would reprocess it to vertical grain, it would be very easy to do. To determine runout you should saw off a square chunk and then hand split in full halves. That will tell you if there is runout or twist. I posted a section in the tutorials section on Bracewood that should be of some help, it was a while ago so will be on the bottom of the first page or even on the second or third page by now. Good luck.
PostPosted: Tue May 17, 2011 2:00 pm
Hi Shane,
Thanks very much for all of the information! I'm still extremely new to this, so it's always great to learn something new. I appreciate it a lot. :)
Users browsing this forum: Bing [Bot], doncaparker and 18 guests
