It is currently Fri Aug 22, 2025 5:35 pm
PostPosted: Thu May 19, 2011 10:21 pm
First name: Ron
Last Name: Y
It's For a Weissenborn Style guitar which is about 40" but the binding from Stew Mac is only 34", so I need to make It longer. Thanks for your help.
PostPosted: Fri May 20, 2011 12:54 am
Why would you bother?
PostPosted: Fri May 20, 2011 7:13 am
First name: Ron
Last Name: Y
Todd Stock wrote:
On curly maple, a short scarf as shown might work better than a longer scarf across more grain lines.
Did you intend to post a picture because I don't see one?
I'm sure It's not difficult with a band saw, which I no longer have because the new craftsman 10" that I purchased a couple months ago had a bad motor so I returned It. I'm holding out for something bigger and better. I thought about just adding the shorter piece to the neck area, but wanted to know how others would do It just to be sure. Thanks
ron
PostPosted: Fri May 20, 2011 8:21 am
First name: Mark
City: Concord
Ron M. wrote:
ron
I wouldn't use a bandsaw for a scarf on a thin piece. This is a job for a small modeler's saw ($5 Zona Razor saw), mini miterbox or shooting board/plane.
PostPosted: Fri May 20, 2011 8:22 am
First name: Ron
Last Name: Y
Hi Todd,
May bad, I forgot that couldn't view photos on my side of the computer because I'm having some flash issues. I went to my wifes side and saw that is was there.
PostPosted: Fri May 20, 2011 8:23 am
Use the main length for the upper and lower bout parts of the bend, scarf the neck or wherever is convenient with a chisel as you work. I don't see how a well done joint is a bad thing, and doing it in advance is a waste of time.
PostPosted: Fri May 20, 2011 8:33 am
First name: Ron
Last Name: Y
Thanks Tony,
Ron.
PostPosted: Fri May 20, 2011 12:01 pm
First name: Ron
Last Name: Y
Tarhead wrote:
Ron M. wrote:
ron
Hi Tarhead,
Actually I was referring to making binding from scratch. I have and intend to use an ex-acto razor saw. thanks
ron
