It is currently Fri Aug 22, 2025 3:01 pm
 Post subject: Jointer Planer parts
PostPosted: Tue Jun 28, 2011 8:57 am
First name: Frank
City: Saranac Lake
My dad gave me an old Montgomery Ward 4" jointer plater from the 50s. Its missing the cutter head and so far my search results come up with cutters costing more then a brand new 4" benchtop jointer. Anyone have any recommendations I can check out. ps. I know I should go to a woodworkers forum but you folks here really know your stuff and I hate to register with more forums then I need to :-). Thanks
Build it cause then you know it's Made in the USA or **insert your country**
 Post subject: Re: Jointer Planer parts
PostPosted: Tue Jun 28, 2011 9:23 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
Hey Frank,
I can't be of too much help, but the folks over at Vintage Machinery Dot Org should be able to help.
Unfortunately, you probably will have to register for their forum... :)
Good luck!
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Tue Jun 28, 2011 3:12 pm
Unless you get very lucky , you will be better off getting a new one or a good used on. Finding parts for something that is 60 yrs old is not easy or cheap.
PostPosted: Sun Jul 03, 2011 2:08 pm
First name: Frank
City: Saranac Lake
The antique forum is great. Registered, checked it out, new time sink for me :-). As far as buying new meh they just not made good unless you want to invest a small fortune even then I tend to question the construction of the newer stuff.
PostPosted: Sun Jul 03, 2011 5:54 pm
Montgomery Wards wasn't as high end as you may think . Walker turner is something else. A good jet would be better money spent that working on the old stuff unless you can find parts at a fair price. Unless you have machinist skills getting things back together and perfectly squared is not as easy as you may think.
PostPosted: Sun Jul 03, 2011 6:21 pm
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Montgomery Ward sold Powr-Kraft machinery. They also sold Duro and McGraw Edison machinery under the Montgomery Ward name.
Duro isn't bad gear at all, so it depends on what Frank has. If he can get the part at a reasonable price, it's probably worth fixing.
I'm swapping out all my Jet machines for old iron. If you know where to look, parts are readily available, and the quality is so much better.
I'll be going to look at a 50's Rockwell cabinet saw this week. $300.00. If I wind up getting it, I'll do a full restoration that will cost around two to three hundred plus my time. When I'm done, I'll have a saw that will blow away a comparable modern saw for a fraction of the price.
It's a give and take. Do you have something worth restoring? Do you have the time, and the skills? Only the person pursuing it can answer those questions for themselves.
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Mon Jul 04, 2011 5:35 am
First name: Frank
City: Saranac Lake
This is more of a side project challenge for me. As far as machining I have my dad to fall back on he has the tools and experience. Navy aircraft mechanic and Embry-Riddle grad.
I know what you are saying blues. Would love to have a full complement of Jet tools in my shop but there is something satisfying about restoring building for yourself be it tools or guitars :-). As my next project will be a homebuilt 18" Bandsaw.
PostPosted: Mon Jul 04, 2011 6:02 am
Walker turner is pretty good if you can find them . Rockwell is another . Chances are some of the old beds may be warped and you need to be careful of cracks and these you often can't see with the naked eye. I did get rid of my old jointer ( craftsman from the 60's) replaced it with a Grizzly and it does the job ok.
I prefer a Shop Fox or Jet but I think they are all made in the same place. The designs are similar but the better machines use a higher grade Motor.
PostPosted: Mon Jul 04, 2011 6:44 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
ADK_Frank wrote:
The antique forum is great. Registered, checked it out, new time sink for me :-)...
If you have time management issues, be careful, I used to spend a lot of time on that forum, I think my wife would say too much.
Kevin Looker
I'm not a luthier.
