Guitar Neck Thickness http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=32695 |
Author: | WudWerkr [ Tue Jun 28, 2011 4:59 pm ] |
Post subject: | Guitar Neck Thickness |
I have examined several Guitars recently in looking at making the neck for my purple heart build. The ones Ive seen ( mainly $200.00 or so guitars ) have a neck thickness of 3/4" at the nut and maintain that thickness to the heel arch . " Thickness measured WITHOUT fingerboard " . Would a Neck not have a better strength factor if it tapered slightly , say for example 3/4" at nut and 1" at heel arch ? What feedback do you have in this regard ? Is 3/4" the standard ? Do others taper the neck ? If No Why ? |
Author: | Chris Pile [ Tue Jun 28, 2011 5:16 pm ] |
Post subject: | Re: Guitar Neck Thickness ? |
Yes, the neck would be stronger if the neck was thicker. No taper seems to be the way many builders and companies are going. With lighter strings, I don't see a problem. |
Author: | StevenWheeler [ Tue Jun 28, 2011 5:19 pm ] |
Hey Jim, Most necks I've seen are tapered. All but one of mine are tapered. I usually rough the blank in a bit over 9/16" at headstock volute and 3/4" at the heel transition. The main concern is to have enough wood left under the trussrod, I shoot for a minimum of 3/16". Steve |
Author: | WudWerkr [ Tue Jun 28, 2011 5:45 pm ] |
That makes sense to me as well , but being new at this I kinda wanted some feedback . On all my Mandolas I have taperd the neck slightly , but then again it is such a small neck to begin with that most dont even notice . However the Guitar neck is larger and it stands out more . I welcome anymore comments on this , Please! ![]() |
Author: | ChuckB [ Tue Jun 28, 2011 6:23 pm ] |
I like to taper my necks. My standard, if it is a spec guitar, is 53/64's at the nut and 61/64's just before heel transition. That is with the fingerboard. Chuck |
Author: | John Mayes [ Tue Jun 28, 2011 6:32 pm ] |
.850 at the first fret is a pretty generic thickness that works well. Of course the shape is just as important (if not more so in many cases) |
Author: | meddlingfool [ Wed Jun 29, 2011 2:23 am ] |
I go 21mm at the first fret avec FB to 24 at the tenth... |
Author: | theguitarwhisperer [ Wed Jun 29, 2011 2:49 am ] |
My neck blanks are 5/8th's with a quarter inch fretboard. I simply round the edges, very slight taper (1/16th inch), very comfortable, plenty strong. |
Author: | Tom West [ Wed Jun 29, 2011 5:57 am ] |
A lot of players like a taper on the thickness. I think that is due to the taper in width of the neck. The taper in thickness gives the same general feel up the neck compared to the ones with no taper. Again just my opinion. Tom |
Author: | Colin North [ Wed Jun 29, 2011 6:14 am ] |
I aim for 21mm at 1st fret and 22 or 23 mm at 9th including fretboard with a C section - (the 22 or 23 mm at 9th depends on how stiff the neck is) For a more triangular section 22/23 at 1st, 24/25 at 9th, same caveat. Of course it can can depend on who is getting the guitar - some people like beefier necks than others. I've heard people say thin necks can be tiring on the left hand if playing for long stretches. |
Author: | WudWerkr [ Wed Jun 29, 2011 1:49 pm ] |
Post subject: | Re: Guitar Neck Thickness |
Thanks everyone . I am gonna stick with my tapered one, as it stands I will be finished size approx 11/16" thick at nut and approx 7/8" -15/16" at heel transition. |
Author: | cphanna [ Wed Jun 29, 2011 6:42 pm ] |
I can't tell you if a gentle taper adds to strength nearer the heel, but logic suggests that it would. What I CAN tell you is that it feels better to a lot a players. I would go so far as to say most players. Anyway, as a player myself, I think an absolutely untapered thickness would feel freakish. |
Author: | alan stassforth [ Wed Jun 29, 2011 8:38 pm ] |
For some reason, the thickness of the neck doesn't seem to affect me.... |
Author: | Howard Klepper [ Thu Jun 30, 2011 1:15 am ] |
To keep the same profile on a neck that tapers in width, you have to taper in thickness. Which IMO is a good thing. |
Author: | WudWerkr [ Thu Jun 30, 2011 9:57 am ] |
Howard Klepper wrote: To keep the same profile on a neck that tapers in width, you have to taper in thickness. Which IMO is a good thing. I have to agree , While a person wants to make a good quality build , it needs to be pleasing to the eye as well . And really THAT was what promted my question more than anything . Strength is important in the neck . But if it doesnt " look " proportional and pleasing no one will pick it up to play it anyway . |
Author: | SteveSmith [ Thu Jun 30, 2011 9:58 am ] |
As a player, I also prefer a tapered neck. Just make sure you don't do this ![]() Happened a while ago, fixed it, put in a new truss rod and fret board. All is well now. Attachment: TrussRodThruNeck.JPG
Author: | WudWerkr [ Thu Jun 30, 2011 10:03 am ] |
I " Truss" you wont do that again ! ![]() ![]() |
Author: | Dave White [ Thu Jun 30, 2011 10:03 am ] |
Howard Klepper wrote: To keep the same profile on a neck that tapers in width, you have to taper in thickness. Which IMO is a good thing. Unless you play a lot with the Capo up and down the neck when a constant thickness helps. It's a player personal thing. |
Author: | SteveSmith [ Thu Jun 30, 2011 12:48 pm ] |
WudWerkr wrote: I " Truss" you wont do that again ! ![]() ![]() ![]() |
Author: | nickton [ Fri Jul 01, 2011 3:14 pm ] |
looks like that lap steel is quite the chick magnet. ![]() |
Author: | alan stassforth [ Fri Jul 01, 2011 8:58 pm ] |
nickton wrote: looks like that lap steel is quite the chick magnet. ![]() When you hit 56 years old, or so, you need all da hep ya can get! |
