It is currently Sat Aug 16, 2025 9:04 pm
PostPosted: Fri Jun 28, 2013 4:10 pm
Beyond the obvious changes that would be necessary to convert a right-hand acoustic guitar to a left-hand model (such as new nut, pick guard, bridge, pin holes, properly compensated saddle slot, etc), is there anything in a typical bracing pattern that would cause any issues acoustically? Or would the bracing not really be an issue?
TIA,
Ken
Ken Mitchell
Durham, NC
PostPosted: Fri Jun 28, 2013 5:19 pm
Shouldn't be a problem....
PostPosted: Sat Jun 29, 2013 6:16 am
First name: David
Last Name: Radlin
City: Belle River
Zip/Postal Code: N0R 1A0
The tone bars would be reversed.
David Radlin
http://www.facebook.com/radlin.guitars
PostPosted: Sat Jun 29, 2013 8:29 am
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
Have you seen Frank's photo essay?
http://www.frets.com/FretsPages/Musician/Guitar/Setup/LeftConv/leftconv.html
Adding fretboard position markers on the other side is another thing to do.
In the discussions that I have seen before the general consensus was that the reversed bracing pattern is not going to affect sound much - and you can't do anything about it anyway.
PostPosted: Sat Jun 29, 2013 8:45 am
Jose Oribe says he quit making differnet bracing for lefthand guitars because there is much lower resale value for lefthanded guitars. He also notes that the sound isn't much different.
PostPosted: Sat Jun 29, 2013 2:06 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I hear many left handed musicians string a right handed guitar backward because they can't find left handed guitars easily. So I guess there's nothing wrong with that. Fender even makes a reverse strat (a left handed strat that has been strung right handed, or vice versa) because Jimi Hendrix used to string a right handed strat in reverse.
Typhoon Guitars
PostPosted: Sat Jun 29, 2013 8:23 pm
Thanks for all of the input, fellows! It confirmed what I was already thinking about the switch-over.
Ken Mitchell
Durham, NC
