Delta Drum Sander Board Motor http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10101&t=40732 |
Author: | SixStringer [ Sun Jun 23, 2013 8:24 pm ] |
Post subject: | Delta Drum Sander Board Motor |
I had a jam-up with a Delta drum sander, the motorized board will now not turn on, but the drum sander will. I thought I could turn on the motor without the sander? Its the last from newest generation BTW. It does not seem to want to work. I would like to bypass the 'control box' with a router motor controller (used for heat blanket) and extension chord when I can find a 2 prong one as a first resort. What size chord would I need for this? Its just the little motor that controls the board. Anyone ever have this? Is there a fuse anywhere? |
Author: | unkabob [ Sun Jun 23, 2013 10:23 pm ] |
Post subject: | Re: Delta Drum Sander Board Motor |
I know nothing about this unit but look for a reset button somewhere around the switch box or on the motor. Just one possibility. Bob ![]() |
Author: | SixStringer [ Mon Jun 24, 2013 9:01 pm ] |
Ok, it looks like that was it, there is a little white dot-button, and it pushes in with a keywrench, its really small. Some people have replaced motors and the whole electronic she-bang on these on other message boards. Its a really innocuous 'button'. You barely notice it. Otherwise I would have bypassed using a router-speed controller I use for the heat blanket. Should have done the same thing, but you need a 2 prong chord that is big enough- if anyone searches this problem. Thanks |
Author: | npalen [ Tue Jun 25, 2013 11:59 pm ] |
The magnets came loose from the inside of the motor housing on my Delta feed motor. They were loose and "banging around". Epoxied them back in place and works fine. |
Author: | SixStringer [ Wed Jun 26, 2013 6:02 pm ] |
I had a jam-up, the board went in sideways and got stuck. |
